#327: 2018 Indian Roadmaster Elite - Coolness Factor = 42.4%
Your Coolness Factor of the 2018 Indian Roadmaster Elite
1
8%
4
33%
4
33%
3
25%
Total votes: 12
2018 Indian Roadmaster Elite on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... te-review/
The ultra-premium Roadmaster®Elite features custom-inspired two-tone candy paint with real 23K gold leaf badging on the tank and lowers.
This paint scheme takes 30 hours to complete and is finished by hand. The Roadmaster Elite comes standard with a large number of premium amenities including the industry-leading Ride Command system, a 300-watt premium audio system, passenger armrests, billet aluminum passenger and driver floorboards, a premium touring console, and pinnacle mirrors.
2018 Indian Roadmaster Elite Totalmotorcycle.com Key Features
Now You Can’t Say The Best Is Yet To Come.
2018 Indian Roadmaster Elite Totalmotorcycle.com Features and Benefits
his ultra-premium touring machine features custom-inspired two-tone candy paint that takes 30 hours to complete and is finished by hand. It’s even embellished with real 23K gold leaf badging on the tank and lowers.
2018 Indian Roadmaster Elite – Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $36,999 USD
Canada MSRP Price: $44,499 CDN
ENGINE
Engine Type
Thunder Stroke® 111
Displacement
111 cu in (1811 cc)
Bore x Stroke
3.976 in x 4.449 in (101 mm x 113 mm)
Compression Ratio
9.5:1
Electronic Fuel Injection System
Closed loop fuel injection / 54 mm bore
DRIVETRAIN
Primary Drive
Gear Drive Wet Clutch
Drive/Driven Clutch
Wet, Multi-Plate
Final Drive
2.2 : 1
PERFORMANCE
Peak Torque
119 ft-lbs (161.6 N m)
Peak Torque RPM
3000 rpm
GEAR RATIO (OVERALL)
1st
9.403 : 1
2nd
6.411 : 1
3rd
4.763 : 1
4th
3.796 : 1
5th
3.243 : 1
6th
2.789 : 1
SUSPENSION
Suspension: Front – Type/Travel
Telescopic Fork / 4.7 in (119 mm) – Cartridge Type
Front Fork Tube Diameter
46 mm
Suspension: Rear – Type/Travel
Single Shock w/Air adjust / 4.5 in (114 mm)
CHASSIS
Brakes/Front
Dual / 300mm Floating Rotor / 4 Piston Caliper
Brakes/Rear
Single / 300mm Floating Rotor / 2 Piston Caliper
Wheels/Front
Cast 16 in x 3.5 in
Wheels/Rear
Cast 16 in x 5 in
Tires/Front
Dunlop® Elite 3 130/90B16 73H
Tires/Rear
Dunlop® Elite 3 Multi-Compound 180/60R16 80H
Exhaust
Split Dual Exhaust w/ Cross-over
DIMENSIONS
Wheelbase
65.7 in (1668 mm)
Seat Height
26.5 in (673.1 mm)
Ground Clearance
5.5 in (140 mm)
Overall Height
58.7 in (1491 mm)
Overall Length
105.4 in (2676 mm)
Overall Width
39.4 in (1000 mm)
Rake
25°
Trail
5.9 in (150.0 mm)
Fuel Capacity
5.5 gal (20.8 l)
GVWR
1385 lbs (628 kg)
Weight (Empty Tank / Full of Fuel)
921 lbs / 953 lbs (418 kg /433 kg)
FEATURES
Color / Graphics
Cobalt Candy over Black Crystal w/23K Gold Trim
STANDARD
Standard Equipment
ABS; Cast Aluminum Frame with Integrated Air-Box; Cruise Control; Highway Bar; Keyless Ignition; Horizon Power Shield; Genuine Leather Seats; Remote Locking Hard Saddle Bags; Remote Locking Trunk; Tire Pressure Monitoring; 300 Watt Stereo with AM/FM, Bluetooth, USB, Smartphone Compatible Input, and Weatherband; Heated Rider & Passenger Seats; Heated Grips; Adjustable Passenger Floorboards; 36.2 Gallons of Storage.
ELECTRICAL
Lights
Pathfinder LED Lights (headlight, driving lights, turn signals, tail light trunk, tail light, trunk interior light, and headdress fender light.)
Gauges
Fairing mounted instrument cluster featuring analog speedometer and tachometer, with fuel gauge, range, odometer and current gear. 15 LED telltale indicators; cruise control enabled, cruise control set,neutral, high beam, turn signal, ABS, check engine, low tire pressure, battery, low fuel, security system, low engine oil pressure and MHP or km/h unit designation
Ride Command®
7″ Indian Touchscreen including realtime clock; ambient air temperature; heading; audio information display; vehicle trouble code readout; Vehicle Status (tire pressure, voltage, engine hours, oil change); Vehicle Info (speed, fuel range, RPM, gear position); Dual Trip Meters (fuel range, miles, average fuel economy, instantaneous fuel economy time, average speed); Ride Data (heading, moving time, stop time, altitude, altitude change); Bluetooth connectivity for phone and headset; Map/Navigation
Re: THIS WEEK: 2018 Indian Roadmaster Elite - VOTE TODAY
From a complete departure from last week's $3300 CCW model, I bring you the brand new 2018 Indian Roadmaster Elite brings ultra touring to the next step.
Many commented on the $3300 CCW lack of quality. But at x11 the cost; is the quality of the new 2018 Indian Roadmaster Elite worth it?
Questions, questions...
montanalifter
Real Name: Bill
Re: THIS WEEK #327: 2018 Indian Roadmaster Elite - VOTE TODAY
#3 Unread post by montanalifter »
Can not say it is uncool, I voted cool.Very pretty. Would rather have a pickup for 37k. If you have the money to spare it is a very nice bike. For me there are lots of super capable nice bikes for a lot less.
ceemes
Real Name: a big secret
#4 Unread post by ceemes »
Another Lazy Boy Recliner on wheels....way over priced, way too big, way too heavy, way too boring, but nice looking......so can't give it a cool or an uncool......going with our none existent "Meh" option.
There are a lot more cheaper option outs there which can pretty much give you most or all the options this bike has with more flexablity and capacity, especially in the sport touring segment.
JackoftheGreen
Real Name: Eric
#5 Unread post by JackoftheGreen »
Yeah...
At some point you gotta ask,why?
Is this really different enough from, say, a Can-Am Spyder RT, to justify the $27k difference in price? If you're really willing to spend that much in order to stay on two wheels rather than a (insert any comment ceemes has made about the Spyder RT's parentage here, :wink: ) then I think you're flirting dangerously close to that "poser" moniker we've debated before.
But, I guess a fool and his money are soon parted. If you wanna spend this much for the street cred, you're welcome to it. But I'm still gonna laugh behind my hand while I pass you on the left. You probably wont notice over the Steeley Dan blaring on the 300 watt sound system though...
markdcoco
Real Name: Mark DiCocco
My Motorcycle: 2014/BMW/R1200RT
#6 Unread post by markdcoco »
For a while I was at a loss for words, but that was only because I had to clean-up my computer after looking at this thing and coffee immediately shooting out my nose.
I like the idea of buying 11 other rides instead of this one. That way you could at least rent them out and make a decent income. Price for this ride is totally prohibitive.
As for looks... I'll defer back to my previous comments about looking like the O-ring end of an elephant going down the road.
Agree fully with all that it is simply a recliner on wheels:
or
I'm certain there's a market for this machine, just glad I'm not part of it.
Gummiente
Years Riding: 38
My Motorcycle: 03 Super Glide
#7 Unread post by Gummiente »
Ok, let's see here... V-Twin type touring bike, check. Disparaging comments by the usual suspects, check. Yep, looks like another normal week in store for the TMW Cool Wall. :)
This one gets a "cool" vote from me, but with a few negative points built in. While I do like the styling, I still can't get my head past those boxy, bulky looking lower fairings. And while I do appreciate the list of technical goodies that are standard, I don't like the fact that there are few, if any, options available to personalise one to individual taste, including a lack of colour options. And yes, that MSRP is a bit on the high side with all the fancy remote gadgets and gold leaf badging. The cost of exclusivity, perhaps?
:canada: Mike :gummiente:
It isn't WHAT you ride,
It's THAT you ride
Grey Thumper
Real Name: Dino
#8 Unread post by Grey Thumper »
If you've got one of these things, more power to you! Different strokes and all that. But I have to admit, I do wonder what is the point at which a motorcycle gets so big as to be pointless. If you want touch screens, that much wind protection, infotainment, premium audio, armrests, lots of luggage, and heated whatever, wouldn't it be more comfortable (and in this case, cheaper) to buy a car?
markdcoco
#9 Unread post by markdcoco »
Gee Boss... don't make us blush :roll:
Gummiente
Years Riding: 38
#10 Unread post by Gummiente »
Grey Thumper wrote: Sun Jul 30, 2017 3:39 pm If you've got one of these things, more power to you! Different strokes and all that. But I have to admit, I do wonder what is the point at which a motorcycle gets so big as to be pointless. If you want touch screens, that much wind protection, infotainment, premium audio, armrests, lots of luggage, and heated whatever, wouldn't it be more comfortable (and in this case, cheaper) to buy a car?
You are aware that all those gadgets and more are available on BMW touring bikes as well, right?
It's THAT you ride
