Starting problem
dan0074
My Motorcycle: 2006 Harley 883 Sportster
Starting problem
#1 Unread post by dan0074 » Sun Jun 16, 2019 10:50 am
HI
I'm having a problem with my HD 883. When I press the starter switch all I get is a fast clicking sound. I am mechanically deficient and have no idea what to do. I did install a fully charged battery. Does anyone have any suggestions? Even a quick simple fix so I could ride it to a garage. I have no other way to transport it.
Thanks
NorthernPete
Years Riding: 11
Re: Starting problem
#2 Unread post by NorthernPete » Sun Jun 16, 2019 7:06 pm
Check your ground wire?
jstark47
#3 Unread post by jstark47 » Mon Jun 17, 2019 10:33 am
Typically, that's a battery that doesn't have enough juice to turn the starter. The clicking sound is the solenoid cycling over and over as it is not getting enough amps. When you say you installed a "fully charged battery".... how was it charged? How old is the battery? There's lots of reasons a battery charger could indicate it is finished charging a battery, yet that battery doesn't have enough capacity to start the bike. If standing battery output is anything less than 12.1 volts, the battery is probably shot.
There's a raft load of other reasons a solenoid could be cycling, but a battery that just doesn't have the required output any more is usually the most common. Bike batteries tend to be more fussy and less robust than car batteries. Repeated undercharging will toast them.
dan0074
#4 Unread post by dan0074 » Sun Jun 23, 2019 8:45 pm
Thanks. I just purchased the battery new and is the same type I've been using. The ground wire was mentioned but I have no idea what that is. I admit I have no mechanical skills at all. This is the first time I've had a problem. Maybe I've just been lucky.
NorthernPete
Years Riding: 11
#5 Unread post by NorthernPete » Mon Jun 24, 2019 6:34 pm
YouTube is your friend in these things. Check your battery terminals, ensure they’re tight. Did you charge your battery up prior to installing?
