New biker question
Posted: Sun Nov 10, 2024 5:04 pm
by anaaustin
Hello,
I just got a brand new Husqvarna Vitpilen 401. After the bike was delivered I started it up and immediately noticed what looks to be water leaking out of the bottom? It seems to be coming from a hole in what looks to be either the catalytic converter or residence chamber? I am wondering if this is normal or a problem?
I am new to motorcycles and I’d appreciate any insight. Thanks.
Re: New biker question
Posted: Thu Nov 28, 2024 4:27 pm
by pharmacyfriend
The water leaking from the bottom of your Husqvarna Vitpilen 401 is likely just condensation from the exhaust, which is normal when the engine starts up. It usually happens when the engine is cold. If the water continues after the bike warms up or there's too much, it might be worth checking for a coolant leak. Otherwise, it's typically not a problem.
Posted: Mon Dec 16, 2024 11:14 pm
by sadiesink951
anaaustin wrote: Sun Nov 10, 2024 5:04 pm Hello,
It’s likely condensation from the exhaust system, which is normal, especially when the engine is cold.
Posted: Fri Jan 10, 2025 8:13 pm
by sabrina
Congratulations on your new Husqvarna Vitpilen 401! What you're seeing is most likely normal condensation from the exhaust system. However,Geometry Dash if you're unsure or see signs of a problem, it's always a good idea to consult the dealer or a certified mechanic to ensure everything is in good working order. Happy riding! 🏍️
Posted: Wed Jan 15, 2025 6:45 pm
by tereit
Congrats on the new Vitpilen 401! That’s a sweet ride. What you're describing sounds pretty normal. It’s likely just condensation from the exhaust system. When the engine heats up, water vapor forms as a byproduct of combustion, and some of it can condense inside the exhaust, especially when the bike is cold. The small hole in the catalytic converter or resonance chamber is a drain to let the water out, so it doesn’t collect and cause corrosion.
You’ll notice it more when starting a cold bike, especially in cooler or humid weather. If it’s clear liquid and stops after the bike warms up, there’s nothing to worry about. If it’s something else (like coolant or oil), that’d be a different story. But from what you’re describing, it sounds totally normal for a new bike
Posted: Tue Feb 18, 2025 2:47 pm
by thatsnot
Congratulations on your new Vitpilen 401!
Posted: Fri Apr 25, 2025 7:10 am
by samsul
What you're seeing is actually quite common, especially with brand-new bikes. The liquid dripping from that small hole (often located at the bottom of the exhaust or catalytic converter) is usually condensation — just water vapor that naturally forms inside the exhaust system when it cools down. That tiny hole is actually a drain hole designed to let moisture escape Tubidy Mp3, preventing rust from forming inside the exhaust.
As long as the liquid is clear and there’s no strong fuel or oil smell, you’re totally fine. If the dripping stops after a few minutes of riding, that's even more confirmation that it’s just condensation.
Congrats on the Vitpilen 401 — it’s a great bike with a lot of style. Ride safe and enjoy every mile..
Posted: Mon Apr 28, 2025 5:23 pm
by Fielaposa
What you're describing sounds completely normal for a new motorcycle. The liquid you’re seeing is likely just condensation from the exhaust system. When the engine is cold, especially in cooler or humid weather, water vapor from combustion can condense inside the exhaust. Most bikes have a small drainage hole in the catalytic converter or resonance chamber to let this water escape and prevent corrosion.
Posted: Mon Apr 28, 2025 8:10 pm
by Teple1960
Normal
It's just condensation dripping from a weep hole in the exhaust.
Posted: Mon Jun 09, 2025 4:36 pm
by Edgar T. Dow
Hey anaaustin, congrats on the new Vitpilen! That doesn't sound quite right. It's likely condensation, especially if it's clear and odorless, but new bikes shouldn't be leaking noticeably. Definitely call your dealer ASAP and send them a pic/video. They'll know for sure. In the meantime, while you wait, if you're itching for some virtual riding, maybe check out a game like Drift Hunters to get familiar with vehicle handling. Good luck!
