shadow 125 oil change
kabbitch
#1 Unread post by kabbitch »
I recently bought a '00 shadow 125. problem is I aint got a clue how to change the oil. had a Yam SR 125 before and that was a doddle. HELP!!!
ultimax
#2 Unread post by ultimax »
you should be able to locate the oil drain plug fairly easily? It's usually a large 14mm screw near the gear shift, on the left side of the bike? There can't be that many big screws there?
