Indicator Trouble
skinnylegs05
Indicator Trouble
#1 Unread post by skinnylegs05 »
Hi,
I fitted a pair of mini indicators to my xlr a few weeks back but the bulbs keep blowing. they are 12v 23W things and i cant understand why they keep popping. It only seems to be the back ones that are blowing though.
Has anyone got any ideas what it could be and/or how to fix them?
XJRJohn
#2 Unread post by XJRJohn »
dont know if this has any bearing ,but on a lot of bikes ,when fitting mini indicators you have to fit a unit to slow them down.if they are flashing to quick this could cause them to blow.can you check the wattage on the originals and on the new ones?see if theres a big diff?xjrjohn
biking isnt a matter of life or death,its far more important(bill shankley,well almost)
old-n-slow
#3 Unread post by old-n-slow »
Check the ground connection on the indicators. I believe a poor ground can do that.
GarryS ---- "We learn from experience that men never learn anything from experience."
Ladymx
#4 Unread post by Ladymx »
Connection or ground as old-n- slow said
skinnylegs05
#5 Unread post by skinnylegs05 »
checked the bulb from the old indicator and that was a 12V 21W bulb.
How do i check the ground connection?
Of the two wires that go into the bulb connector, 1 goes inside and the other wraps around the bulb connector.
I have noticed on a few of the bulbs that the filament is very close to the outside glass casing of the bulb... could this be a factor?
