Indicator Trouble
Posted: Sun Mar 20, 2005 9:09 am
by skinnylegs05
Hi,
I fitted a pair of mini indicators to my xlr a few weeks back but the bulbs keep blowing. they are 12v 23W things and i cant understand why they keep popping. It only seems to be the back ones that are blowing though.
Has anyone got any ideas what it could be and/or how to fix them?
Posted: Sun Mar 20, 2005 9:46 am
by XJRJohn
dont know if this has any bearing ,but on a lot of bikes ,when fitting mini indicators you have to fit a unit to slow them down.if they are flashing to quick this could cause them to blow.can you check the wattage on the originals and on the new ones?see if theres a big diff?xjrjohn
Posted: Sun Mar 20, 2005 1:34 pm
by old-n-slow
Check the ground connection on the indicators. I believe a poor ground can do that.
Posted: Sun Mar 20, 2005 2:56 pm
by Ladymx
Connection or ground as old-n- slow said
Posted: Mon Mar 21, 2005 6:42 am
by skinnylegs05
checked the bulb from the old indicator and that was a 12V 21W bulb.
How do i check the ground connection?
Of the two wires that go into the bulb connector, 1 goes inside and the other wraps around the bulb connector.
I have noticed on a few of the bulbs that the filament is very close to the outside glass casing of the bulb... could this be a factor?
