NO's 2 &3 not firing
skidz
#1 Unread post by skidz »
I have an '81 CB 750. Last week it suddenly lost alot of power. After looking into it I figured out the 2 & 3 don't seem to be firing as the pipes on those 2 never get hot.
I tried switching the coils around and got the same thing. I switched the spark units around too..same thing. New plugs made no difference either. Mechanical?
Any help is greatly appreciated as usual!
Thanks in advance!!!
niterider
#2 Unread post by niterider »
Check the compression on those cylinders. The head gasket may have burned between the cylinders.
nitrus
#3 Unread post by nitrus »
check for spark on those coils with the plugs out, if no spark, you may have an open somewhere.
skidz
#4 Unread post by skidz »
O.K. I checked the spark and there is one...a little one. So I'll have to do that compression test ( gonna need the manual for that one ). Any other thoughts? Bugger is I really don't want to put much more into this bike as I'm buying a new one in the spring but I'd like to ride through the fall!
