1991 CBR starting problem
daught
#1 Unread post by daught »
Well I got myself a 1991 Honda CBR 600cc. Well the bike has not been started in 4 years untill yesterday. Me and my dad were on it for 2 days to get it runing and we finally did. When we got it runing it worked damn well. No problems. So I had my fun riding it around and put it back in the garage. Next morning it did not start again. To get it started I had to put a few drops of gas into those air intake holes on the carb (btw how are they called in english?). Then it started right off. Restarting is no problem. If I leave it more then one hour then again it wont start and again I have to put gas in the carb then it runs fine. So any ideeas why it wont start after siting one hour?
Gadjet
Real Name: Owen Clark
Years Riding: 19
#2 Unread post by Gadjet »
Are you using the choke when you start the bike?
If you aren't, then you will have a hard time starting the bike when it's cold. The choke dumps more fuel into the cylinders making it easier to start and get warmed up; you close the choke when the bike has gotten warmed up.
part 3 is the choke cable and part 4 is the choke lever.
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
daught
#3 Unread post by daught »
Yes I am using full choke and I saw it working. I think there just isnt any gas to fire up. When I try to restart it rumbles for a second then dies. I think since my gas pump uses vacuum it dosent get enough vacuum when trying to start it I dont get any gas in the carb. When I shoot gas in the carb with the siringe it has enough gas to start and make vacuum to continue runing. Could that be it?
Gadjet
Years Riding: 19
#4 Unread post by Gadjet »
you may have a vacuum leak on the petcock vacuum line then. Replace that hose and see what happens. If that doesn't help the problem, you're only out a dollar or so and you have a new line.
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
sidecarguy
#5 Unread post by sidecarguy »
it dont have a prime position?
too feed the carb by gravity?
jean b.
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
