Help!
peterman
Help!
#1 Unread post by peterman »
Hey does anyone know what I should torque my sparkplugs at? It's a 1982 yamaha maxim 400. And also does anyone know what they should be gapped at? I can just use the old sparks as a guide until I figure it out if no one knows.
thanks for looking
Skier
#2 Unread post by Skier »
Gaps might be printed somewhere on the bike itself. Under the seat of my '86 Yamaha Radian, it has that information, I believe.
As for spark plug torque, put a tiny bit of anti-seize on the threads and tighten them down via the instructions on the plug packaging. It varies by the sealing washer used, but it's usually 1/4 to 1/2 turn after it's snug (I usually say snug is about 1/8 turn past handtight).
sidecarguy
#3 Unread post by sidecarguy »
heres the ngk website.
it might help! :oops:
http://www.ngksparkplugs.com/apps/motor ... 0&country=
jean b.
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
peterman
#4 Unread post by peterman »
thanks a lot, that package actually says its a full 1/2 turn given the washers it came with. I look around for the gap. I put them in and it fired right up! Man I was so pumped, after 9 years it purrs!!!!!
After a while (10-15 minutes) it seems to get bogged down and just dies. When I pulled the plugs they were BLACK. I am guessing the float needs to be adjusted and I need to lean out the carb. Unfortunately I have no idea how to do either of those. I'll look around here though, I'm sure there is some information somewhere.
thanks again!
sidecarguy
#5 Unread post by sidecarguy »
if u need more specific help goto
http://www.xjowners.com
or there is cd that has everythinh about xj's
http://members.tripod.com/dave_jack/id47.htm#xjcd
u got any pocs o'the bike? :motorcycle:
jean b.
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
peterman
#6 Unread post by peterman »
I really need to get one now that it's put back together. I got the tank in the mail last week and couldn't wait so I put it all back together. To see if it would run. Now I need to take some pictures.
The tank looks worse on the outside than the one I had but no rust on the inside. I may be repainting the tank this winter if I can get the balls to do it.
