blaaack plugs!
Posted: Tue Nov 01, 2005 2:08 am
by sidecarguy
my jawa 350 640 '95 was runing fine
with the sidecar until a couple of days ago.
if just started to bog down
and now it fouls op plugs in like 5 blocks?
i had to use like 4 paris of plugs just to get home!!
where should i start trouble shooting
gas flooding or electrical? :?
Posted: Tue Nov 01, 2005 3:43 am
by niterider
I think it is flooding.
Posted: Tue Nov 01, 2005 4:57 am
by sidecarguy
hmm i just took the carb apart
and rechecked everything since i just
took it apart last week and we'll see how it goes.
there is a little pipe that goes in some passages
and comes out the other side which i suspect is blocked.
any tips on hoe to clear it? i tried poking but since its
all curvy and stuff i cant really clean it!! :cry:
Posted: Tue Nov 01, 2005 9:11 am
by storysunfolding
I always take my carbs apart, remove anything rubber and plastic and put her in a chemical dip overnight. Makes them shiny as new and dissolves most gunk. Then I spray the leftover dip off with carb cleaner, blow some compressed air through the passages and put back together. Takes a bit of time but it's solved every carb problem I've ever had.
Posted: Tue Nov 01, 2005 11:19 am
by sidecarguy
whatkindofchemicaldip? :(
im afraid if i leave them overnight in acid it'll eat them away!
ok ya, to be on safe side i'll take it off again and do it!
Posted: Tue Nov 01, 2005 11:23 am
by storysunfolding
It won't hurt the metal but it will eat rubber. I've been told that plastic is ok, but I never tested it myself and don't plan to.
As for the dip, just get whatever they have at the autoparts store near you. It's all the same thing.
Posted: Wed Nov 02, 2005 1:06 am
by sidecarguy
which is?
Posted: Wed Nov 02, 2005 7:23 pm
by niterider
Just ask for carb cleaner it should be in a bucket that has a small tray in it to put the parts in while soaking. The cleaner is reusable.
