blaaack plugs!
sidecarguy
blaaack plugs!
#1 Unread post by sidecarguy »
my jawa 350 640 '95 was runing fine
with the sidecar until a couple of days ago.
if just started to bog down
and now it fouls op plugs in like 5 blocks?
i had to use like 4 paris of plugs just to get home!!
where should i start trouble shooting
gas flooding or electrical? :?
jean b.
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
niterider
#2 Unread post by niterider »
I think it is flooding.
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
sidecarguy
#3 Unread post by sidecarguy »
hmm i just took the carb apart
and rechecked everything since i just
took it apart last week and we'll see how it goes.
there is a little pipe that goes in some passages
and comes out the other side which i suspect is blocked.
any tips on hoe to clear it? i tried poking but since its
all curvy and stuff i cant really clean it!! :cry:
jean b.
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
storysunfolding
Years Riding: 22
#4 Unread post by storysunfolding »
I always take my carbs apart, remove anything rubber and plastic and put her in a chemical dip overnight. Makes them shiny as new and dissolves most gunk. Then I spray the leftover dip off with carb cleaner, blow some compressed air through the passages and put back together. Takes a bit of time but it's solved every carb problem I've ever had.
My Blog
Grasp life by the handlebars
sidecarguy
#5 Unread post by sidecarguy »
whatkindofchemicaldip? :(
im afraid if i leave them overnight in acid it'll eat them away!
ok ya, to be on safe side i'll take it off again and do it!
jean b.
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
storysunfolding
Years Riding: 22
#6 Unread post by storysunfolding »
It won't hurt the metal but it will eat rubber. I've been told that plastic is ok, but I never tested it myself and don't plan to.
As for the dip, just get whatever they have at the autoparts store near you. It's all the same thing.
My Blog
sidecarguy
#7 Unread post by sidecarguy »
which is?
jean b.
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
niterider
#8 Unread post by niterider »
Just ask for carb cleaner it should be in a bucket that has a small tray in it to put the parts in while soaking. The cleaner is reusable.
1993 750 Vulcan
one seater
horn relocation
