only 1 cylinder firing on a 1981 cm400e
92civeg
#1 Unread post by 92civeg »
both cylinders have spark to them when i checked them and i just cleaned the carbs, i dont know much about electronic ignition systems can anyone throw out some things to check?
the carbs are not sycronized i have to give it gas to keep it running maybe this is part of the problem?
thanks-johnny
#2 Unread post by BuzZz »
Sounds very much like a carb/fuel delivery problem rather than an electrical one. You might have to go through the carbs and clean them out good.......
