Helmet Advice
Bx RedBull
Helmet Advice
#1 Unread post by Bx RedBull »
What is the major difference between the following two helmet shells and which one would make for the better dome protector? :frusty:
Fiberglass/Kevlar Shell
or
Polycarbonate Composite Shell
Also, any opinions or comments on Scorpion helmets?
Shiv
#2 Unread post by Shiv »
I'm always told that, as far as protection goes, as long as it passes the DOT then you're good to go.
As far as weight, I believe the polycarbonate is a lot lighter and thus probably more comfortable.
Have fun on the open /¦\
www.totalmotorcycle.com
I know, I was surprised too.
#3 Unread post by Sev »
They're both about the same in terms of protective ability, fibreglass/kevlar will be a lot lighter, make sure that the helmet is at least DoT approved, SNELL is good too.
moto_hanki
#4 Unread post by moto_hanki »
Polycarbonate shells are heavier, but ususally only by a few ounces. Poly is generally cheaper because it can be mass produced quickly by injection molding.
Fiber-glass/Kevlar is a lighter material and both materials are extremely strong. The fiberglass is a weave of tiny glass particles that is made into mats that have to be presses into a mold. These products cannot be produced as quickly and easily as poly and therfore more expensive.
I wrote a paper last summer for a technical writing class and found out a lot of cool info.
Henri
1992 Seca II XJ600
SuperRookie
Real Name: Daryl
My Motorcycle: 2004 Ducati 620ie
#5 Unread post by SuperRookie »
Also, don't forget to read the "Helmet fit guidelines" sticky if you haven't done so already. If it doesn't fit right, and you happen to have a get-off and bang your head wearing an ill-fitting lid it won't matter what it was made of.
"Not just your 'ordinary' Rookie..."
jmillheiser
#6 Unread post by jmillheiser »
Best advice I can give. Make sure its DOT approved and it fits
