having problems with starting my motorbike
hondaxl125r
#1 Unread post by hondaxl125r »
im an owner of a honda xlr125r.It is used every day and working ok on saturday night fine when i came to use in on sunday morning it would not start,replaced the plug and and there was a spark, plenty of fuel,could u please help? the year of the bike is 1985 please contect with any suggestments thanks luke
honda xl 125r
Skier
#2 Unread post by Skier »
Start with the basics. You need air, fuel, spark and compression.
Verify the spark plug fires when the threads are grounded to the engine somewhere.
Make sure there's gas in the tank, and the carb bowls have some in them as well.
Make sure the air filter isn't clogged.
Verify there's compression (using a compression tester)
Hopefully it's something silly like being out of gas!
hondaxl125r
#3 Unread post by hondaxl125r »
full tank of fuel i dont have a compresstion teaster what happens if the compressons has go? how can that been fixed cheers luke
honda xl 125r
Skier
#4 Unread post by Skier »
Try giving this a read, should give you some more hints, including the answer to your latest question:
http://www.dansmc.com/troubleshooting2.htm
Good luck.
