Foward Controls
schooney
Foward Controls
#1 Unread post by schooney »
I have recently purchased a 1982 Yamaha XJ650J Maxim and was wondering if it is possible to put foward controls on it. I love the bike just want to move the brake and shifter up to a more comfortable position. I also want to add floor boards. Any advice?
RegalSwan
#2 Unread post by RegalSwan »
I personally like the controls where they are, but if you want a quick fix id recommend some "Highway Pegs" attached to the engine guards. I like them because I can have my legs under me in sportier maneuvers (getting on any highway in Minneapolis at 8am) but then if I am cruising for any period of time my legs can stretch out a bit. I can understand your desire though, im 6' 1" or so, depends on the gas station, and it felt cramped for the first couple hundred miles.
"I like a man who grins when he fights"
-Winston Churchill
'07 SV650 "Charlotte"
'82 Maxim 650 "Charon"
schooney
#3 Unread post by schooney »
Thank you for the advice, i will look into the highway pegs and see if that is what I am looking for.
schooney
#4 Unread post by schooney »
Looked at some highway pegs and they would work, except I am looking to move the brake and gear shifter up to the same place the highway pegs would go. Does anyone now if that is possible and if so were can i purchase the hardware?
bok
#5 Unread post by bok »
if you know how to weld i bet anything is possible. not sure if there are any kits that you can just bolt on, but check out cruisercustomizing.com never ordered from them, but got a bunch of good ideas so far
schooney
#6 Unread post by schooney »
Thanks for the info. Will look into it.
Wizzard
#7 Unread post by Wizzard »
Google J&P Cycles . They have lotz of great stuff for metrics .
Best regards, Wizzard
YZFRider
#8 Unread post by YZFRider »
I had the same bike for several years, and never saw what you are looking for, and I was searching eBay and the web regularly for parts. Unfortunately, the age of your bike means less is available than it is for newer crusiers from sources like J&P.
As already mentioned, putting pegs on the case guards may be your only option unless you can find a fabricator to weld extensions on the brake and clutch.
99 Yamaha YZF600R
schooney
#9 Unread post by schooney »
Thank you guys for the different web sites to look at and information. I have gone to several of the sites and have gotten some great ideas. Again thanks for the info.
