90 weight gear oil for my chain?
norsseman
Location: In the Country. Far back in the deep dark woods. Geiger Heights, Washington
#1 Unread post by norsseman »
Have made up my mind to use 90 weight oil for my chain. Is it
gear oil that I should buy? What brand do you recommend?
A Canadian Adventure tour site for the KLR650 says that they get
3 times the mileage out of 90 weight oil than other types of chain
lube. Also my manual recommends 90 weight oil.
Freedom is not Free
oldschoolorange
#2 Unread post by oldschoolorange »
get any 80 90 brand outhere if it is just being used for chain lube, Maby you want to go with 80 90 EP EP = extreme pressure, this is used mostly in hypoid gearsets it the rear ends of cars/trucks, The additive just sticks to the metal better and wont be rubbed off as easily
83 GS550, 70 Yamaha CT1 175
