Help! NO KEY!
rt1maillady
Help! NO KEY!
#1 Unread post by rt1maillady »
I bet one of you can help me with this problem! :oops:
I just got a parts bike, A 1980 Honda CM400T. No key! I am sure there is an easy way to take care of this problem. There is apparently a code on the bike for the key. Does anyone know about this? Do you know where the code would be on this bike? Thanks!
KarateChick
#2 Unread post by KarateChick »
Can you contact your local automotive motor association (CAA/AMA) and ask them for the locksmiths they use? These guys typically are able to come in and make some sort of ignition impression (wax or such) and then can cut a key for your bike.
CNF2002
#3 Unread post by CNF2002 »
Locksmith maybe, but its probably cheaper just to buy a new ignition switch that does have a key :)
2002 Buell Blast 500 /¦\
logitech104
#4 Unread post by logitech104 »
try here (part numbered 3)
http://houseofmotorcycles.bikebandit.co ... CM400T.asp
and honda keys for more info
http://www.hondakeys.com/
and a couple parts sites for kicks...
http://www.partsnmore.com/
http://www.hondarestoration.com/
http://www.Bikebandit.com/
and some wiring diagrams
http://oldmanhonda.com/MC/WiringDiagram ... .php#class
too much info i know.. :mrgreen:
Z (fka Sweet Tooth)
#5 Unread post by Z (fka Sweet Tooth) »
CNF2002 wrote:Locksmith maybe, but its probably cheaper just to buy a new ignition switch that does have a key :)
I agree, and then make a spare key. Yes, I speak from experience.
2006 VTX 1300 R
sharpmagna
#6 Unread post by sharpmagna »
Actually a good locksmith can make a key if you bring them the ignition for less than $10.
1987 Honda <B>SUPER</B> Magna
logitech104
#7 Unread post by logitech104 »
sharpmagna wrote:Actually a good locksmith can make a key if you bring them the ignition for less than $10.
really? i didn't know that... i was told to use as a last resort because of how expensive it was.. cool. :D
sharpmagna
#8 Unread post by sharpmagna »
Your prices may vary, but my friend got a key cut from a local locksmith for $10. The only thing the locksmith needed was the ignition.
rt1maillady
#9 Unread post by rt1maillady »
This forum is great. So much knowledge being shared. Thanks for all the information. At least it sounds better than I thought. I think I will put in some phone calls to local locksmiths and see if I can get someone to work with me on this. Thanks to all!
Sue
