Engine - how hot is ok ?
Suzuki gs500e
After I've ridden a while and park it most everything like muffler/pipes and even cylinder fins cool off so I can put the cover on it.
But it takes a lot longer for the crankcase covers to cool, for like about 30 mins or longer they're hot enough (can't leave your hand on them more than a couple secs) that the cover would melt, or catch fire (?)
Is this normal for motorcycles ?
- Ninja Geoff
- Real Name: Geoff
- Years Riding: 7
Does the bikie have a warning light or temp gauge? As long as that doesn't go off/read too high, it'll be fine. If you have the owners manual, it should list in there the very upmost temp that's safe to operate at. I know with my bike, it's 239 degrees F.
Re: Engine - how hot is ok ?
If you cant touch it after 30 min.. should have it looked at. My 250 cools off supper fast ( well doesnt get hot that much)superskip wrote:Suzuki gs500e
SILENTX
Current: NINJA 250
# Accidents: 1
# Mishaps/close calls: 4 (Rider at Fault: 1.5)
# Stupid/Risky moves: 2
BE SAFE, RIDE SAFE, HAVE FUN, MAY FORCE BE WITH YOU
[img]http://img80.imageshack.us/img80/9686/dsc07031sa0qf6.jpg[/img]
Current: NINJA 250
# Accidents: 1
- VermilionX
- Years Riding: 6
- My Motorcycle: '06 Suzuki GSX-R 750
- DivideOverflow
- Legendary 1000
You boys want hot... my Duke normally operates between 250 and 260 degrees F. hehe. But it is aircooled, and I don't think my hi-temp warning goes on until 300 F or so.
2008 BMW K1200S
2003 Z1000 - For Sale
2004 Hyosung GV250 - sold
- flynrider
- Years Riding: 30
Holy cow, D.O.! That's hot! What are you using in the crankcase, lava? Most motor oils start to break down at around 250F. Are you sure that temperature is normal?DivideOverflow wrote:You boys want hot... my Duke normally operates between 250 and 260 degrees F. hehe. But it is aircooled, and I don't think my hi-temp warning goes on until 300 F or so.
Bikin' John
'93 Honda CB750 Nighthawk
- storysunfolding
- Years Riding: 22
Right on. this is normal. consider a cover with the protective heat panels along the bottom. dowco makes great coversflynrider wrote:The metal on the upper part of the engine cools relatively quickly in the air. The crankcase contains several quarts of hot uncirculating oil. It's going to take a longer time to cool. That is normal.
wrong.silentx wrote: if you cant touch it after 30 min.. should have it looked at
