honda cb250 w. w`ont start
homer63
#1 Unread post by homer63 »
i have a honda cb250 w, 1999- t reg, it has been stood since august 2006
the choke cable had seized up so i replaced it ,tried yo start it and it w`ont
start. there`s a brand new battery on it and i drained the petrol off and refilled it, it`s firing ok but will not start can anyone help please. [/b]
Re: honda cb250 w. w`ont start
#2 Unread post by BuzZz »
Stand-by for the barrage of 'clean the carbs' replies to follow.... :wink:
I'll just mention the other obvious thing...... make sure you have spark at the plugs as well.
logitech104
#3 Unread post by logitech104 »
clean the carbs
#4 Unread post by Johnj »
You said it'll fire. Did you pull the plugs to see if they spark, or does it sometimes kinda backfire through the carburetors? You could have the coils wired backwards.
:roll: Or you might need to clean your carbs.
dablade
Real Name: Perry Crowell
My Motorcycle: 2005 Yamaha FJR 1300, 2004 GL1800 ABS
#5 Unread post by dablade »
if you can get it to fire off on carb. cleaner or propane, it is a fuel delivery problem (most likely).
did someone say clean the carbs.....
