Suzuki C50
canuckerjay
Suzuki C50
#1 Unread post by canuckerjay »
My bud just bought one of these -- I have searched all over for the power specs on this (torque & HP bands) and can't find them. does anyone know where to get them?
Wherever you may roam
May you own your road.
#2 Unread post by Wrider »
Well, it's the exact same motor as the M50, so it's within 5 or 6 of 50 horsepower, and 50 lb/fts of torque...
gsJack
My Motorcycle: 02 GS500
#3 Unread post by gsJack »
Sounds about right, August 05 Rider dyno run shows 45.1 HP at 5900 rpm and 44.8 lb-ft torque at 3400 rpm for the EFI M-50.
Earlier Dec 01 MCN showed 39.9 HP at 6000 rpm and 42.5 lb-ft torque at 4000 rpm for 02 Volusia with carbs.
The Volusia got a nice little HP boost from the EFI when it became the C-50.
407,211 miles in 30.1 years for 13,528 miles/year average. Started 7/21/84, updated 8/26/14
#4 Unread post by Wrider »
That's for sure, they definitely got a boost over the carbs. The real problem with the carbs is that they ran SO lean. Plus to make them pass emissions, they also used a PAIR valve to add more air to the exhaust. After the EFI, they don't have the PAIR valve and they also don't need to warm up for so long...
basshole
#5 Unread post by basshole »
if you want detailed HP & Torque info on the C-50 got to volusiariders.com You'll find a ton of info on that there.
Beer. Helping ugly people get laid since 1853
2006 Suzuki C50 Silver/Gray
