Starter Clutch from Ebay - Slightly damaged
shoto
#1 Unread post by shoto »
Hey guys, I just orderd a starter cltuch for my Honda CB650, 1979.
The springs appear to be garbage, they are worn and deformed, lost most the spring in them. That's fine, these can be replased cheap.
However, the starter clutch itself has some wearing on it already, and I'm curious to know if it is going to cause the bike to not start, or make that "whiiiiiiiiiiir" sound still. I haven't seen my SC to compare the damage, but I'm wondering how much damage there has to be to have a problem.
Thanks!
(Pics soon)
shoto
#2 Unread post by shoto »
Anyone?!
CORSCO
#3 Unread post by CORSCO »
I'd say you just pissed your money away on a beat up starter clutch. Starter clutches don't like any abnormalities. Please pull out your wallet and do it right the first time and buy a NEW ONE :wink: Not being harsh, you never know if you don't try. I just like doing a job ONCE. Good luck.
shoto
#4 Unread post by shoto »
Hrmm. So you think that the starter clutch will be pretty rough to start then?
eclipse_dude
#5 Unread post by eclipse_dude »
Hey man i just had this problem
i have honda cb 650 from 1980 and i had the same problem with the starter clutch and springs and rollers.
You can probably get new springs to put in and it could last you to the winter but if the springs are worn at all they are garbage. If the starter clutch has ANY wear at all its gonna make a weird sound and wont start unless the engine is warm. Mine only had a few nicks in it no longer than half my fingernail and it wouldnt start unless i tried for like 10 mins
Hope i could help keep us posted!!!!
Outlaw_1784
starter clutch
#6 Unread post by Outlaw_1784 »
hey i've just bought an old 1980 honda cb650 custom and im not sure but i think its the starter clutch. the starter is good but when i put my finger on the sprocket i can turn it easily. what part and or parts do i have to get and how to i fix it? any ideas on where i can get the parts?
honda750
#7 Unread post by honda750 »
check and see if an expanding pin holding the gear onto the starter is good, then u might have to replace clutch,
you can generally get any starter parts pretty easily from the manufacturer.
blue moonshine plants
insaneman_12
Years Riding: 25
My Motorcycle: Motorcycle
#8 Unread post by insaneman_12 »
Hate to give you the bad news, but on a 79 CB 650 you have to split the cases to replace the startor clutch. The springs only give enough pressure to push the rollers towards the gear. The main thing is that the rollers grab onto the gear when turned in the proper direction.
71 CB 750 K1
94 PC 800
76 CB 550 K
75 TS 185
76 TC 185
63 YSA-1
06 YZ 450F
84 XL 350R
02 KX 85 with 75 XR 75 motor XR 200 sus.
