One thing was to replace the pan. $600 or $700 with labor. Another was to remove the pan and have the hole built up again by a welder. Still a couple hundred to have the work done anyway. I wanted to find something else. That was a big bill for a small mistake.
So ZooTech, a previous member of this board, who was banned for some silly banter on his part, suggested a few things. He mentioned these inserts that could be put into the hole, which would compress both inside and outside the hole, and would have a bolt that could be removed from this sleeve, which would make a new drain hole, although smaller.
He also mentioned an oversize bolt, which was made for automotive applications, and also had an alternative thread, and was self cutting. This was a very cheap fix, and I gave this one my first try. It did work. I threaded it in a bit, and backed it out, and cleaned it. Did that several times until I felt the threads were cut and I was putting no metal bits in the pan. Once I tightened it down though, I was afraid to remove it again for the fear of finding threads loose again. The pan is pretty soft, at least on my bike.
Since this next season started I've been afraid to change my oil for fear of wrecking the pan. Another idea Zoo had mentioned was a product from Fram, called Sure Drain. It would go in place of the oil plug and it puts a new fitting in its place. Once installed you never have to unscrew the oil plug again. You just hook on a special drain tube, and the oil comes out through the check valve. I'll add some pictures later. It also has a cap to go over the fitting to protect it between changes. Since I was nervous about my pan threads, I added thread tape when I installed the new fitting, and there is no leak. In the future I will never fear messing up the pan.
Once I get a picture from my bike I'll cross link this to the product reviews.
