Lost VIN Number- Where do we find it?
Do you know where your VIN is?
Poll ended at Tue Jul 03, 2007 1:51 pm
Yes
3
100%
Yes, I know all the spots
0
No votes
Total votes: 3
Timetonut
#1 Unread post by Timetonut »
Hi everybody.
I am in the great spot of buying the same model and make of motorcycle I first learned on. A 1982 Yamaha Maxim 550. The trick I have run into is that part of the sticker VIN Number (redundant, I know) has been torn. The middle part. I know that the VIN matches the VIN somewhere on the engine. So here is the big question:
WHERE CAN I FIND THE ENGINE #?
WHERE CAN I FIND THE VIN?
Is it possible to fill in the middle if we have the beginning and ending numbers?
Thanks,
Jon
Timetonut
slimcolo
#2 Unread post by slimcolo »
Should be stamped on the frame, usually on the neck.
SEE NO EVO
HEAR NO EVO
SPEAK NO EVO
and above all
RIDE NO EVO
Read my blog
JC Viper
Real Name: JC
#3 Unread post by JC Viper »
It should be stamped or engraved on the frame itself either near the neck, down tubes or engine casing. If not then take off the seat and look in the battery area.
The engine # should be on the engine itself, probably near the oil filler area.
With my bike it was under the VIN sticker on the neck, kinda redundant I guess.
ofblong
Real Name: Ben
#4 Unread post by ofblong »
JC Viper wrote:It should be stamped or engraved on the frame itself either near the neck, down tubes or engine casing. If not then take off the seat and look in the battery area.
yeah but better than losign the number :D
96' Honda Shadow Deluxe VLX
slimcolo
#5 Unread post by slimcolo »
Some are located on bottom tube of frame, under engine.
SEE NO EVO
HEAR NO EVO
SPEAK NO EVO
and above all
RIDE NO EVO
Read my blog
ofblong
Real Name: Ben
#6 Unread post by ofblong »
slimcolo wrote:Some are located on bottom tube of frame, under engine.
thats where mine is.
Timetonut
Thanks Everyone
#7 Unread post by Timetonut »
Thanks for all the help. Between the different variations, my friend and I were able to find the vin and use it for a title transfer. I am now VERY VERY proudly commuting back and forth from work everyday. Now I am having fun discovering the quirks of a 25 year old machine. It still runs like a champ, but has it's issues.
Still learnin'
Still riding.
Jonathan
Timetonut
