??? about re-gearing a Honda Shadow ACE
monkers
#1 Unread post by monkers »
I have a 2000 Honda 750 Shadow ACE and so far I love the bike with one exception. When riding on the highway (65MPH) the bike seems to be revving pretty high. Can I drop down two teeth on the rear sprocket and take a link out ? It just seems to need another gear on the highway. How badly will this effect my low end? Thanks for the help,
Craig
#2 Unread post by Sev »
How high is pretty high? I seem to recall that a shadow has a redline somewhere around 8000 to 9000 rpms. My buddy runs his as 140km/h regularly with no adverse affects so far. It's 3 years old now.
mswarrior
#3 Unread post by mswarrior »
Doesn't taking teeth out raise the RPM?
Many say live to ride, I say ride is to live.
#4 Unread post by BuzZz »
On the rear sprocket, adding teeth will raise the rpm needed to hold any given speed. Subtracting teeth will lower the rpm needed to hold the same speed.
On the front sprocket, the opposite is true. More teeth = less rpm
Abner
#5 Unread post by Abner »
If you lower you cruising RPMs, I think you will also loose some low end power and torque. But if you do mostly high speed cruising and don't mind losing acceleration power, I guess it would be okay.
Instead of changing the sprokets, you could also get a slightly taller tire, it would have the same effect. Smaller tire, higher RPM but faster accelaration.
You need to add another gear, but the only problem with that is you would need a new transmission. The easiest way to get a new trannie, is to get a new bike. An I know that's expensive :frusty:
Black 2005 Honda Spirit 1100
