Helmets
RevBrian
Helmets
#1 Unread post by RevBrian »
I'm in the process of deciding what kind of helmet to purchase. I have pretty much decided on a full face but was wondering if there were any thoughts about brand and fibreglass vs poly carbonate. Welcome your thoughts.
#2 Unread post by Johnj »
I say go to the dealers and check helmet sizing, then order on the Internet.
First and foremost is fit. We could suggest a brand, but it may not fit your head.
Whatever helmet you end up with, make sure it is not just DOT, but a step above with a Schnell or ECE standard.
KBC, Shark, Arai, Shoei, Bell, Nolan, ...there are so many....
ILOVECRUISER
#4 Unread post by ILOVECRUISER »
DING !!! I THINK MANY FAMOUS BRAND ARE GOOD ENOUGH! YOU SHOULD CHOOSE WHAT IS YOUR FAVORITE AND FIT !!顶你上去,让大家看看!!!哈哈哈哈!!
SAVE THE EARTH !
jonnythan
#5 Unread post by jonnythan »
Get the helmet that has the best combination of fit, looks, and price.
The only thing the expensive helmets might get you is better ventilation and a washable liner.
The shell material really doesn't matter a bit.
Nibblet99
#6 Unread post by Nibblet99 »
jonnythan wrote:The shell material really doesn't matter a bit.
It was my understanding (read: deep, dark, distant memory) the fibre ones have a longer shelf life, and aren't susceptable to problems cause by solvents found in sticker glue.
(something like 4-5 years as opposed to a poly carbs 2-3 years - either way 1 impact voids the remainder of the lifespan on both though, which you should expect to happen)
I could however be very, very wrong, so please do some research rather than taking what I've written here as fact
jonnythan
#7 Unread post by jonnythan »
The shell material is not the limiting factor in shelf life - the EPS foam is.
ABS and other plastics should not be damaged by sticker glue, either.
