It starts, but then doesn't 5 minutes later
Hey everyone, thanks for having me on this forum
I recently purchased a 2006 Honda Shadow Spirit 750. I got it about 3-4 weeks ago and it worked great. Had to charge the battery once a week ago and already replaced the spark plugs. Started it up today, let it idle for about 4 minutes then it died. Tried to start it back up and the starter wouldn't even turn, just an annoying click from the battery. Dead battery right? I tried it again about an hour later and it started right up and ran fine. I shut it down and tried to start it again and just the same clicking noise. The lights, turn signal, and horn work fine even when it wont start.
Is the battery just bad? or is there a short somewhere? do i need a new starter?
Please help me, the weather is beautiful and I can't ride!
- ofblong
- Legendary 2500
- Real Name: Ben
I just had this problem on my bike. Found the wires going to the stator motor 1 was cut in half, second was almost cut in half, and the third wire was starting to wear through. So I put quick disconnect terminals on the 3 wires and then put heat shrink over them to keep water out.
96' Honda Shadow Deluxe VLX
- ofblong
- Legendary 2500
- Real Name: Ben
glad to hear BUT I would still go over all the wiring. I put a new battery in my bike and it lasted about 2 months before it died because of bad wiring.Chemical Duke wrote:hey guys i got it all fixed now, just had to change the battery. It's running great now! Thanx for all your tips and help!
i agree
ya i agree with ofblong
something else to make sure you do is start up the bike and while its idling unhook the battery. if it keeps running well it means the alternator is fine.
put a meter on the battery connections and rev it.
the voltage should be around 14 volts - that means it's charging.
between that and all the wiring you should be good.
history of us recessions
