Again, thanks.
ErnCol
+100 on the front brake. I have seen more people bust their a$$ by using the front brake in loose ground, i.e. gravel, sand, dirt, rock, etc. I know thats what they teach you in MSF, but remember MSF has a purpose to teach new or non riders how to drive a motorcycle in a parking lot. It's good for those who need that, but my issue with it is they DO NOT make you ready to face the beast on the public roads. That is the beast to master, the slab. Ride safe...Zagnut wrote:Do things slow and easy. If your going straight, not too slow...a little speed will give you a bit more stability than going too slow....kinda ride over the gravel rather than through it.
If you are turning, do it slow and easy and maybe even keep your feet down or at least ready to be put down quickly as stabilizers.... and dont even think about using the front brake!...back brake only!... Grabbing front brake in gravel will drop you like a hot potato.
lol you obviously dont know anything about the MSF then. They teach you how to avoid problems AT SLOW SPEED on the road. Go ahead dont use that front brake and only use the back. we will be laughing when you fall on your arse.cruiserV wrote:+100 on the front brake. I have seen more people bust their a$$ by using the front brake in loose ground, i.e. gravel, sand, dirt, rock, etc. I know thats what they teach you in MSF, but remember MSF has a purpose to teach new or non riders how to drive a motorcycle in a parking lot. It's good for those who need that, but my issue with it is they DO NOT make you ready to face the beast on the public roads. That is the beast to master, the slab. Ride safe...Zagnut wrote:Do things slow and easy. If your going straight, not too slow...a little speed will give you a bit more stability than going too slow....kinda ride over the gravel rather than through it.
our licence tests can't be passed with just the back brake, and since 80% of your braking power comes off the front you would think people would learn how to use it. I had one old biker tell me if I needed to make an emergancy stop that i should lock up the back put it in a slide and jump off the bike. WTF? doesn't that leave me bikeless and out in the middle of traffic? I think most problems with the front brake are people just don't know how to use them and do a full on method of brakingSkier wrote:I am absolutely amazed riders still don't think the front brake should be used, even in low-traction scenarios. It's still providing a vast majority of braking force and it's a good plan to ignore it?
Boggling.
Skier, the pic you posted is not a gravel road...its a hard packed dirt road and I have traveled many of them and I use the front and back brakes simultaneously when stopping or slowing on them. however...when turning in loose gravel as I stated in my earlier post...Avoiding the front brake is silly. Grabbing the front brake on any surface will "drop you like a hot potato." Use it but use it properly.
You go ahead and use your front brake turning around in a flex base parking lot, Oblong.. and I'll try not to laugh my azz off as I help you lift your bike up off the ground....after all that would be rude wouldn't it?Go ahead dont use that front brake and only use the back. we will be laughing when you fall on your arse.
use any of your brakes while turning is asking for disaster be it on a smooth cement road or gravel.Zagnut wrote:Skier, the pic you posted is not a gravel road...its a hard packed dirt road and I have traveled many of them and I use the front and back brakes simultaneously when stopping or slowing on them. however...when turning in loose gravel as I stated in my earlier post...Avoiding the front brake is silly. Grabbing the front brake on any surface will "drop you like a hot potato." Use it but use it properly.
I still say lay off the front brake...not much "braking force" is needed when turning in loose gravel at slow speeds. I would venture to say that most if not all street bike riders don't do much turning at 50 mph in a loose gravel parking lot therefore maximum braking force isn't needed to scrub off speed
the only time Ive ever dropped my current bike was turning into a loose gravel parking lot and I was slowing with both front and back brakes like I normally do....bike upright in a wide turn..and my front tire slipped out
I use my front brake all the time...unless Im in loose gravel, in fact many times I slow down or stop with only my front brake. You would be hard pressed to get my bike to drop using the front brake on concrete..unless maybe it was wet. My front brake does the lions share of all my stopping on the road
In loose gravel, I use the back brake gently and never have a sliding problem. If however, my back tire should start to slip.. its much easier to steer through a back tire slipping than a front one.. and Im not talking high side speeds here ...
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
Follow us on X / Twitter - Facebook - YouTube - Pinterest - Instagram - News RSS Feed |
