Need help finding the problem
I have a 1980 GS550E it has been sitting in a barn for the past few years and now i`m trying to get it started . cleaned and had carbs rebilt . new plugs and ( nothing , ) plugs are dry . not getting fuel i think . bowls are full and i got spark . don`t know if it week or not but i can see spark .
Any ideas ?
Greg
Any ideas ?
Greg
- Real Name: Ryan
If the carbs were just rebuilt I'm not sure why you're not getting fuel. Are you holding the throttle open when you try to start it? If not try that and see if the plugs get wet. If it still doesn't make sure they put the jets back in and cleared them out completely.
- coffee_brake
- Legendary 300
Just recently had some trouble with a '82 GS450 that had spark and fuel but wouldn't fire. It turned out to be the ground from the CDI box (this one has a ground to the electrical panel, go figure). It actually had good spark but after fixing the CDI ground, it had GREAT spark.
Good luck, keep us posted...
Jenn S.
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
- Johnj
- Real Name: Johnny Strabler
First off, have you acquired a manual for your bike? If not I recommend you get one.Cler12000 wrote:Hi Merry Christmas to all
I Have not been working on the bike much . I got frustrated with it . time to fix this thing i was told to look into the ignition system . i was told to look to see if the bike has points of Electronic ignition , anyone know what i`m dealing with ?
I do know the '78 550 has electronic ignition, so the '80 should have it too.
- crazypj
Its electronic, they all are (GS500twin NEVER came with points)
Sitting probably gunked up the carbs, they need cleaning properly, particularly pilot and starting circuits. The pilot screw had an EPA plug and is factory pre-set so you need to drill out plug, count turns to bottom screw (gently) and write numbers down so you can put it together properly
PJ
PJ
I'm not a complete idiot, but I'm working on it
There are three types of people in the world, those who can count and those who can't
