My first upgrade for my V-Max. edit: now my second
BudmanTom
#1 Unread post by BudmanTom »
I have heard plenty about T-Boost kits so I splurged and bought one ($40), installation took just over half an hour and it worked the 1st time out... Great bang for the buck.
Tom
"God give me patience, but give it to me now!!! D.W."
2005 VTX 1800
2005 450R
1999 KLR 650
1996 ZX-11
Aggroton
#2 Unread post by Aggroton »
i didnt know those things could get any faster :laughing:
thats a sweet bike.
BudmanTom
#3 Unread post by BudmanTom »
Aggroton wrote:i didnt know those things could get any faster :laughing:
Plenty of mods left ;)
2005 VTX 1800
2005 450R
1999 KLR 650
1996 ZX-11
bennettoid
#4 Unread post by bennettoid »
so explain to me what it does.
'94 vulcan 750
#5 Unread post by dr_bar »
bennettoid wrote:so explain to me what it does.
If I'm correct, it drops the RPM that the T-Boost kicks in. I believe that the stock setting is around 6000rpm and the kit allows it to kick in at 3000rpm. If you've ever ridden a V-Max you'll know that up around 6-7000 rpm, that thing just gets up and goes... If you thought you had to hang on before, you better make sure you're crazy glued to that seat when that sucker kicks in... :D :shock: 8)
Now what is the T-Boost? Simply put, it is a set of butterfly valves that allows two carbs to feed one cylinder, controlled by a servo. Hmmm that's like putting a rocket boost system on a bike like that... :shock: :shock:
ZooTech
Years Riding: 18
#6 Unread post by ZooTech »
Yeah, but I thought the point of waiting until 6000rpm was the fact that the engine doesn't need to breathe that freely at lower RPM's. It's like artificially activating VTEC in a Honda Civic earlier than designed. If you get "on the cams" before the fuel demands justify it, you're not doing yourself any favors.
BudmanTom
#7 Unread post by BudmanTom »
ZooTech wrote:Yeah, but I thought the point of waiting until 6000rpm was the fact that the engine doesn't need to breathe that freely at lower RPM's. It's like artificially activating VTEC in a Honda Civic earlier than designed. If you get "on the cams" before the fuel demands justify it, you're not doing yourself any favors.
I bought mine with a switch so I can feel the difference of it being on and off, you don't feel the v-boost kickin as hard @ 3k as you do at 6k.
Tom
2005 VTX 1800
2005 450R
1999 KLR 650
1996 ZX-11
iwannadie
#8 Unread post by iwannadie »
since when is anything stock at its peak ability? stock is always the most conservative settings/design. same with bumping the psi on your turbos.
yamaha probally figured the motor would run longer if the boost didnt kick in untill 6k. or maybe that was the safest(flying off the seat effect) or who knows what they are thinking. but obviously it has a gain from kicking in at 3k.
03 katana 600
BudmanTom
#9 Unread post by BudmanTom »
Ordered a Corbin seat, the stock seat is killing me on rides that last over an hour (or I'm just a wimp).
2005 VTX 1800
2005 450R
1999 KLR 650
1996 ZX-11
iwannadie
#10 Unread post by iwannadie »
is there a fender eliminator kit out there? ive seen a few that had no or next to no fender. it looks pretty nice with no fender beyond the back of the seat i think. not sure if its just some people cutting the fenders or they sell them?
03 katana 600
