CB360 Cafe now for sale!!
flyboy712
#1 Unread post by flyboy712 »
Here is a picture of my CB360 Finished. Thanks for looking and for all the replies/help last spring!!
Image[/img]
fireguzzi
Real Name: Trevor
#2 Unread post by fireguzzi »
Looks pretty awesome. Very clean.
paul246
#3 Unread post by paul246 »
Looks great! Just wondering if you plan to put a front fender in place and do you have the battery hidden somewhere?
Honda XR650L Dual-Sport
RhadamYgg
#4 Unread post by RhadamYgg »
That is such a clean look. What rearview mirrors are you using?
Fargo360
My Motorcycle: 1998 Honda VTR1000 SuperHawk 996
#5 Unread post by Fargo360 »
Are those clip ons or a clubman bar?
1976 Honda CBR360R/T
flyboy712
#6 Unread post by flyboy712 »
Clip on handle bars, Mirrors are some that I found in a local shop here in Washington, they fit inside the handle bars then expand to stay put 3" diameter. Not putting the fender back on and the battery is behind the engine sitting on the rear arm iff you look close you can see it has a grey top. It's a small gel battery 3.5 amp hour or something like that. Basically just used to settle down the charging system and smooth things out. I removed the starter and put an expanding rubber automotive block plug in the hole, its all kick start so far its only taken about two kicks when it" really cold and when it's warmed up about a 1/4 kick and she goes. I use a Garmin NUVI 155W GPS for my speed and trip meter its just held on with some industrial strength Velcro. It works well with gloves too. Individual Pod air filters and the exhaust is the straight 12" shorty pipes from JC whitney using a 110 main jet in the carbs and then a little idle mixture adjustments and it seems to run good. I get two pops after letting off the throttle and plugs look good so good enough for me.
Still using points for the ignition they are working good so far had problems getting them going. If you are having spark problems clean everything and I mean everything and use good name brand points. DO NOT USE THE CHEAP CHINESE ONES THEY SUCK!!! I know I went through two brand new sets of defective ones.
Here are a couple more pics:
Battery:
GPS Mount:
The right side:
Let me know if you have any other questions!!
Thanks,
#7 Unread post by BuzZz »
That's a cool bike. Nice work.
Any idea what it weighs? I'm a heavy fan of light. :mrgreen:
jaskc78
My Motorcycle: N/A
#8 Unread post by jaskc78 »
that bike is just sweet. awesoem job, flyboy.
flyboy712
#9 Unread post by flyboy712 »
Thanks for the comments!! It weighs about 305lbs. I think stock is about 395lbs.
Fargo360
#10 Unread post by Fargo360 »
I'm looking to do something like that with mine. Where did you get the clip ons from? I like the look of those more than the clubman bar. Anyone know if a cb550 tank will fit on a 360 frame?
