CB360 Cafe now for sale!!
- Years Riding: 10
Here is a picture of my CB360 Finished. Thanks for looking and for all the replies/help last spring!!
[/img]
- RhadamYgg
- Years Riding: 7
- My Motorcycle: 2006/Yamaha/FZ6
That is such a clean look. What rearview mirrors are you using?
- Years Riding: 10
Clip on handle bars, Mirrors are some that I found in a local shop here in Washington, they fit inside the handle bars then expand to stay put 3" diameter. Not putting the fender back on and the battery is behind the engine sitting on the rear arm iff you look close you can see it has a grey top. It's a small gel battery 3.5 amp hour or something like that. Basically just used to settle down the charging system and smooth things out. I removed the starter and put an expanding rubber automotive block plug in the hole, its all kick start so far its only taken about two kicks when it" really cold and when it's warmed up about a 1/4 kick and she goes. I use a Garmin NUVI 155W GPS for my speed and trip meter its just held on with some industrial strength Velcro. It works well with gloves too. Individual Pod air filters and the exhaust is the straight 12" shorty pipes from JC whitney using a 110 main jet in the carbs and then a little idle mixture adjustments and it seems to run good. I get two pops after letting off the throttle and plugs look good so good enough for me.
Still using points for the ignition they are working good so far had problems getting them going. If you are having spark problems clean everything and I mean everything and use good name brand points. DO NOT USE THE CHEAP CHINESE ONES THEY SUCK!!! I know I went through two brand new sets of defective ones.
Here are a couple more pics:
Battery:
GPS Mount:
The right side:
Let me know if you have any other questions!!
Thanks,
Battery:
GPS Mount:
The right side:
Thanks,
