is there an electrician around? - Page 2 - Total Motorcycle Community Forums
Skip to content
Advanced search
  • Quick links
    • Unanswered topics
    • Active topics
    • Search
  • FAQ
  • Login
  • Register
  • Search
  • Unanswered topics
  • Active topics
  • Print view
Advanced search
  • Previous
  • 1
  • 2
bei
Real Name: Bei
My Motorcycle: 2004/Suzuki/Gixxer 1000
Re: is there an electrician around?
  • Quote
#11 Post by bei » Mon Apr 19, 2010 2:07 am
some more pics
bei
Real Name: Bei
  • Quote
#12 Post by bei » Mon Apr 19, 2010 2:11 am
If you pay more attention to the front wheel, you can see a black tied down to the wheel to create a tension to hold the front end of the bike low. But the speedo stays at 0mph no matter how fast i go and also the milage won't add up as well.. weird
bei
Real Name: Bei
  • Quote
#13 Post by bei » Mon Apr 19, 2010 2:16 am
Buzz
You recommended to refer to the service manual for checking the speedo and odo meter, I have downloaded a version online, do you happen to know that if there is voltage flow to the meter which shows on the panel cluster cuz it stays at "0MPH" and able to see the total milage and trip a and trip b mileage, so that means that there is power going to the sensor, so do you think that there might be some thing else to it? because the "0MPH and the odo does not add up while the bike is ridden.
bei
Real Name: Bei
  • Quote
#14 Post by bei » Mon Apr 19, 2010 2:18 am
man, tomorrow my appointment with the dealer is gonna cost me an arm & leg, just for a diagnostic to find out why the meters don't work, and who knows what other damages will show up on this bike. crossing my fingers
  • Quote
#15 Post by BuzZz » Mon Apr 19, 2010 9:02 am
If the speedo has power (as yours obviously does) and does not register actual speed, it points to a problem with the speedo sensor. Either a bad connection or a toasted sensor. The gauge cluster is not seeing a signal from the sensor, for some reason.
  • Print view
  • Previous
  • 1
  • 2
Jump to
  • ↳   Total Motorcycle Talk
  • News, Events and Stories
  • Reviews
  • Rider Cafe'
  • Off Topic!
  • Total Motorcycle General
  • Board index
  • All times are UTC-11:00
  • Delete cookies
  • Contact us
Privacy | Terms
