1980 KZ1000 LTD
JOHNboyDAVIS123
Real Name: JOHN DAVIS
My Motorcycle: Year/Make/Model1980 KZ 1000
1980 KZ1000 LTD
#1 Unread post by JOHNboyDAVIS123 »
STILL HAVENT FOUND ANY HELP ON HOW TO TIME THIS KZ1000 MOTOR I KNOW WERE TO PUT THE CRANKSHAFT I JUST DONT KNOW ALL ABOUT THE CAMS ITS CLOSE I KNOW BECAUSE IT WILL START BUT IT JUST ANT RIGHT .
Last edited by JOHNboyDAVIS123 on Fri Jul 09, 2010 12:32 am, edited 1 time in total.
JOHNboyDAVIS123
1980 KZ1000 LTD
#2 Unread post by JOHNboyDAVIS123 »
DOES ANY BODY KNOW WERE OR WITCH DIRECTION THE CAMS NEED TO POINT OR SHOULD I SAY THE TIMING MARKS NEED TO POINT WHEN PUTTING THIS ENGINE BACK IN TIME.
Last edited by JOHNboyDAVIS123 on Fri Jul 09, 2010 12:27 am, edited 1 time in total.
Re: 1980 KZ 1000
#3 Unread post by Wrider »
Re: 1980 KZ1000 LTD
#4 Unread post by Johnj »
I suggest that you get a service manual for your bike. The procedure takes about three pages the explain.
JOHNboyDAVIS123
Re: 1980 KZ1000 LTD
#5 Unread post by JOHNboyDAVIS123 »
I KEEP TRYING AFTER I POSTED THIS AND IT FINALLY CAME BACK TO ME AFTER A FEW MORE TRYS I GOT THE OLD BIKE GOING IT RUN GREAT BUT THANKS FOR THE HELP . ITS PRETTY SIMPLE PUT CRANK AT TDC THEN PLACE INT CAM SO MARKS ARE INLINE WITH GASKET SURFACE MAKE SURE THE SLACK IS OUT OF CHAIN FROM CRANK TO INT CAM THEN COUNT 28 PINS AT THE 28TH PIN PUT YOUR EX MARK AND THERE YOU HAVE IT PUT ALL YOUR CHAIN IDLERS IN PLACE THEN YOUR TENSIONER IN PLACE AND SPIN THE MOTOR SLOWLY AND CHECK ALL YOUR MARKS THEY SHOULD BE AOK.
ceemes
Real Name: a big secret
Re: 1980 KZ1000 LTD
#6 Unread post by ceemes »
Good to hear you got it sorted. However, posting in all caps is considered to be shouting and somewhat rude.
