1980 KZ1000 LTD
- Real Name: JOHN DAVIS
- Years Riding: 30
- My Motorcycle: Year/Make/Model1980 KZ 1000
1980 KZ1000 LTD
STILL HAVENT FOUND ANY HELP ON HOW TO TIME THIS KZ1000 MOTOR I KNOW WERE TO PUT THE CRANKSHAFT I JUST DONT KNOW ALL ABOUT THE CAMS ITS CLOSE I KNOW BECAUSE IT WILL START BUT IT JUST ANT RIGHT .
Last edited by JOHNboyDAVIS123 on Fri Jul 09, 2010 12:32 am, edited 1 time in total.
- Years Riding: 30
1980 KZ1000 LTD
DOES ANY BODY KNOW WERE OR WITCH DIRECTION THE CAMS NEED TO POINT OR SHOULD I SAY THE TIMING MARKS NEED TO POINT WHEN PUTTING THIS ENGINE BACK IN TIME.
Last edited by JOHNboyDAVIS123 on Fri Jul 09, 2010 12:27 am, edited 1 time in total.
- Real Name: Ryan
Re: 1980 KZ 1000
http://www.kawasakimotorcycle.org/forum ... iming.html
That's your best bet it seems.
- Johnj
- Real Name: Johnny Strabler
Re: 1980 KZ1000 LTD
I suggest that you get a service manual for your bike. The procedure takes about three pages the explain.
- Years Riding: 30
Re: 1980 KZ1000 LTD
I KEEP TRYING AFTER I POSTED THIS AND IT FINALLY CAME BACK TO ME AFTER A FEW MORE TRYS I GOT THE OLD BIKE GOING IT RUN GREAT BUT THANKS FOR THE HELP . ITS PRETTY SIMPLE PUT CRANK AT TDC THEN PLACE INT CAM SO MARKS ARE INLINE WITH GASKET SURFACE MAKE SURE THE SLACK IS OUT OF CHAIN FROM CRANK TO INT CAM THEN COUNT 28 PINS AT THE 28TH PIN PUT YOUR EX MARK AND THERE YOU HAVE IT PUT ALL YOUR CHAIN IDLERS IN PLACE THEN YOUR TENSIONER IN PLACE AND SPIN THE MOTOR SLOWLY AND CHECK ALL YOUR MARKS THEY SHOULD BE AOK.
- ceemes
- Real Name: a big secret
- Years Riding: 26
Re: 1980 KZ1000 LTD
Good to hear you got it sorted. However, posting in all caps is considered to be shouting and somewhat rude.
