Changing handgrips...
Can I just replace the handgrips on a 1986 Ninja by just replacing the worn grip over the perfectly functional throttle slide?
Thanks,
Hakx
Rookie Restoration - Stupid question number 1..of many
- Johnj
- Real Name: Johnny Strabler
Re: Rookie Restoration - Stupid question number 1..of many
Yes
- Real Name: Ryan
Yup, either cut or blow them off with compressed air, then use grip glue (or go cheap and use aquanet hairspray) and slide the new grips on! Works as a lube then when it dries it works as a glue, best of both worlds!
