noobie wrote:Thanks Gummiente,
So if I change the suspension on the shocks - how will that effect single riding? And is that something I can do myself - or do I have to bring it into the shop?
Noobie
Peace Out
Like Jon says, there should be details on how to do that in your owners manual. Usually it involves the use of a special wrench that comes with the bike's tool roll, it's an odd looking thing with a curved body and a little tab at the end. Looks a lot like a scythe. You hook the tab in one of the holes near the bottom of the shock absorber collar below the spring, wrap the curved end around the shock absorber collar and then rotate the lower part of the shock up to the next setting - you'll see a sort of ramp stop with 5 settings on it, you want to put it at or near the highest one. Be advised that it will take a bit of effort to operate the tool and you can end up with skinned knuckles if it slips, causing you to bang your hand into various hard and sharp bike parts and inventing new swear words in the process. Make sure that both shocks are set to the same setting when you're done, or it will cause handling problems! And don't forget about the chain slack adjustment; for that you might want to get your local shop to do the dirty work.
In answer to your question about single riding, youhave two choices; leave the bike as is, which means the chain will run with a little more slack than usual and the ride will be a bit more harsh because the shocks are set higher, or you can adjust the chain and shocks every time you switch from single to double riding. Obviously, the second choice will be time consuming and a pain in the arse, so you might find it easier to leave things set up for 2-up riding.
