2011 Victory Zach Ness Vegas
http://www.totalmotorcycle.com/photos/2 ... sVegas.htm
It’s clear that third-generation custom builder Zach Ness has learned well from his legendary grandfather and father. Yet Zach’s personal design style comes through on the Zach Ness Signature Series Vegas 8-Ball. This understated yet stunning custom features several Ness accessories, custom paint and graphics by Zach, a custom leather seat and more.
The Vegas 8-Ball has a laid back approach to performance and design, with a streamlined solo seat, lowered seat position and foot pegs. All designed so you remain comfortable hours down the road.
Key Victory Zach Ness Vegas Key Features
Ness holeshot engine covers: The Ness Holeshot styling theme is featured on the engine. The same styling is also found on the handgrips and footpegs, giving the bike an integrated custom treatment.
Numbered badges: Each limited-edition bike has a metal plate with the bike's number, the Cory Ness logo and a facsimile of Cory's autograph.
Custom stitched leather seat: Ride in comfort and style on the custom stitched leather seat created especially for the Zach Ness Signature Series Vegas 8-Ball.
Key Victory Vegas 8-Ball Key Features
New Blacked out 106-Cubic-Inch Freedom V-Twin: The blacked-out engine provides a stylish centerpiece for the Vegas 8-Ball, plus, it provides an incredible 97 hp and 113 ft.-lb of torque.
2011 Victory Zach Ness Vegas - Specifications
USA MSRP - $18,999 USD
Canada MSRP - $21,189 CDN
Engine
Engine Type 4-stroke 50o V-Twin
Cooling System Air / oil
Displacement 106 ci / 1731 cc
Bore x Stroke 101 x 108 mm
Compression ratio 9.4 : 1
Valve train Single overhead camshafts with 4 valves per cylinder, self-adjusting cam chains, hydraulic lifters
Fuel Capacity 4.5 gal / 17.0 ltr
Exhaust Staggered slash-cut dual exhaust with crossover
Oil capacity 5.0 qts / 4.75 ltr
Charging System 38 amps max output
Battery 12 volts / 18 amp hours
Primary Drive Gear drive with torque compensator
Clutch Wet, multi-plate
Transmission 6-speed overdrive constant mesh
Final Drive Carbon Fiber Reinforced Belt
Chassis Dimensions
Length 96.0 in / 2439 mm
Wheelbase 66.3 in / 1684 mm
Seat Height 25.2 in / 640 mm
Ground Clearance 5.3 in / 135 mm
Rake/trail 32.9o / 4.9 in / 126 mm
Dry Weight 645 lbs / 293 kg
GVWR 1,151 lbs / 522 kg
Suspension
Front Suspension Conventional telescopic fork, 43 mm diameter, 5.1 in / 130 mm travel
Rear Suspension Single, mono-tube gas, cast aluminum with rising rate linkage, 3.0 in / 75 mm travel, preload adjustable spring
Brakes
Brake Systmen Type Conventional
Front braking system 300mm floating rotor with 4-piston caliper
Rear braking system 300mm floating rotor with 2-piston caliper
Wheels and Tires
Front Wheel 21 x 2.15 in
Rear Wheel 18 x 5.5 in
Front Tire 90/90 21 Dunlop Elite 3
Rear Tire 180 55-B18 Dunlop D417
Color Options
Colors Matte Black w/ Ness Graphics
