2012 Indian Chief Vintage
http://www.totalmotorcycle.com/motorcyc ... intage.htm
Based on the 1948 Chief, the 2012 Indian Chief Vintage's two-tone paint schemes, chrome Indian tank badge, and fender light take you back to the era where the Indian Chief ruled the highway.
Distressed tan leather with fringe covers the solo seat and saddlebags to give the Chief Vintage a distinctive nostalgic look.
60-spoke chrome wheels with classic whitewall tires complete the vintage appearance.
Colors: Thunder Black, Indian Red, Willow Green & Ivory Cream, Indian Red & Ivory Cream, Arizona Turquoise & Winter White.
2012 Indian Chief Vintage Features and Benefits
Styling
" Chromed teardrop halogen headlamp
" Auxilliary driving lamps
" Die-cast console - color matched
" Black and polished engine with chrome covers
" Chromed spoke wheels
" Two-into-one stainless steel exhaust system with three-way catalytic converter and chromed shields
" Long skirt fenders and dual-tone paint available
" Metal tank badge
" Chrome fender tips
" Engine guards
Powertrain
" Air-cooled pushrod Power Plus 105ci engine
" Closed loop, sequential, port injection with heated oxygen sensors
" Six speed transmission Chassis
" Solo seat, with passenger pillion available in destressed tan leather with fringe
" 5.5 gallon fuel tank
" Brembo brake system with dual floating rotors and 4 piston calipers in the front, and single floating rotor and two piston caliper in the rear
" Two accessory 12V outlets
" Quick-release windshield
" Vintage saddle bags in distressed tan with fringe
Electrical
" Tank-mounted analog speedometer and multi-function digital display
" Charging system: 42 amps
" Lamps: teardrop headlamp, glass front fender light, auxilliary spot lights
" No electrical relays
2012 Indian Chief Vintage - Specifications/Technical Details
MSRP Price: $35,999 Solid color, $36,899 Two-Tone color, USD
Dimensions
Length 100.5"
Width 40.5"
Height 50.5"
Seat Height 27.25"
Wheelbase 68.4"
Dry Weight 753 lbs
Gross Vehicle Weight 1260 lbs
Rake Steering Head/Trail 34°/5.92"
Engine
Engine Type Power Plus 105, Air-Cooled
Displacement 105 Cubic Inches
Bore x Stroke 3.966" x 4.25"
Compression Ratio 9 to 1
Fuel System Closed Loop Sequential Port Fuel Injection
Drivetrain
Primary Drive Chain
Gearbox Six Speed
Gear Ratio (overall)
1st 3.77:1
2nd 2.56:1
3rd 1.87:1
4th 1.44:1
5th 1.15:1
6th 1.1:1
Final Drive Belt
Chassis
Frame High tensile steel
Suspension/Front Diameter 41 mm/Travel 4.25"
Suspension/Rear Single shock/travel 2.90"
Brakes/Front Dual Caliper with Floating Rotors
Brakes/Rear Single Caliper with Floating Rotor
Tires/Front 130/90-16 White Wall
Tires/Rear 150/80-16 White Wall
Wheels Spoked wire
Exhaust System Two-into-one stainless steel
Electrical
Electrical Instruments Aanalog speedometer and muti-function digital display
Charging System 42 Amps
Lamps Teardrop headlamp, glass front fender light, auxillary spot lights
Warranty 2 Years
Pricing $35,999 Solid color, $36,899 Two-Tone color
Colors
Thunder Black
Indian Red
Standard equipment
Long Fenders
Solo Seat w/ Passenger Pillion
Vintage Leather Saddlebags
Windshield
Leather Fringe
Chrome Grab Rail
Chrome Fender Tips
Engine Guards
