Is this RPM normal?
- xRider
- Regular
- Real Name: Marc
- Years Riding: 0
- My Motorcycle: Motomia Enzo 150cc
Is this RPM normal?
I was riding my new bike a bit and was wondering if this RPM is normal. I was in 4th gear and going 50kmph and the RPM was 5000. The bike has 5 gears and can go up to 100kmph so is this normal?
Dream Bike
2006 Ducati Sport 1000
- Johnj
- Real Name: Johnny Strabler
Re: Is this RPM normal?
Yea
- xRider
- Regular
- Real Name: Marc
- Years Riding: 0
So will it say this way or change after a while?
Dream Bike
- Real Name: Ryan
Ummm what? It's a fixed ratio. If your clutch and chain aren't slipping it will always be a certain RPM in a certain gear at a certain speed.
Marc, you'll find (generally) the bigger the engine the lower the RPM at X speed (for the same type of engine, ie, 4 cyl or twin).
To answer your question, 4,000 rpm at any speed is fine. What you want is a sweet spot between "cruising along" and "get out of the way power" ... so if crusing along is at 3,500 rpm and get out of the way power starts a 5,500 rpm, then 4,000 is good.
Keep asking your questions, I'm sure you are learning more and more each day from the answers.
- xRider
- Regular
- Real Name: Marc
- Years Riding: 0
Thanks for the replies
and I'll definitely keep asking questions.
Dream Bike
- Real Name: Ryan
- Years Riding: 0
- My Motorcycle: 1985 Honda Nighthawk 650
Every bike is different, but generally prefer higher revs. I have an 85 Nighthawk 650, and at first I was running it routinely between 3K-4K. My dad then told me they like it higher....4K at the lowest, probably ideally at 5K.
All of a sudden I went from avg. 40 MPG to about 50 MPG. So I would consult a forum for your specific make/model.
- Johnj
Wait a minute...in 4th gear @ 5000 rpm your doing 50 thousand miles per hour?xRider wrote:I was riding my new bike a bit and was wondering if this RPM is normal. I was in 4th gear and going 50kmph and the RPM was 5000. The bike has 5 gears and can go up to 100kmph so is this normal?
- BobK
- Legendary
- Years Riding: 43
I guess it's not a Harley.Johnj wrote:Wait a minute...in 4th gear @ 5000 rpm your doing 50 thousand miles per hour?xRider wrote:I was riding my new bike a bit and was wondering if this RPM is normal. I was in 4th gear and going 50kmph and the RPM was 5000. The bike has 5 gears and can go up to 100kmph so is this normal?
- Real Name: Ryan
He's got a really big turbo and very high gears...
