2012 Suzuki GSX1250FA Touring: Voted - Awesome
Your Coolness Factor of the 2012 Suzuki GSX1250FA ST/SEA Touring is...
View results
More photos and information: http://www.totalmotorcycle.com/motorcyc ... ouring.htm
Think of the 2012 Suzuki GSX1250FA ST / GSX1250FA SEA Touring as a kinetically charged invitation to enjoy the ride of your life. It has a fuel-injected powerplant with loads of torque and a wide powerband, which gives it awesome acceleration in every gear matched by heart-pounding top-end performance. It features advanced suspension front and rear, giving you the advantage when the road turns twisty.
With its fully faired design, the 2012 Suzuki GSX1250FA ST / GSX1250FA SEA Touring rewards you with a smooth and comfortable highway ride mile after mile after mile. It also has Suzuki's Digital Antilock Brake System (ABS) for optimum braking performance. The 2012 Suzuki GSX1250FA ST / GSX1250FA SEA Touring - with exciting performance and truly versatile capabilities, it's an all-around sportbike at an exceptional value.
For 2012, it's available in Metallic Alba Blue, Glass Splash White and Glass Sparkle Black.
A sports tourer made for turning any spot on the map into a precious memory.
Whether touring, commuting or just having some fun, the 2012 Suzuki GSX1250FA ST / GSX1250FA SEA Touring is never short on excitement, providing the rider with ample power and torque for a comfortable ride. This is the machine that defines a weekend, but can also be relied on every day of the week.
the fully faired 2012 Suzuki GSX1250FA ST / GSX1250FA SEA has a fuel injected double overhead camshaft (DOHC) powerplant with 1255cc of torque at your service. Delivering a wide spread of power, starting low down in the rev range, the six gear ratios takes full advantage of this torque resulting in extra smooth acceleration and inspiring power delivery, perfect for long distance rides.
The 2012 Suzuki GSX1250FA ST / GSX1250FA SEA also offers a quality luggage system comprising of 33 litre panniers (per side) and a 37 litre top box making it truly the ultimate go anywhere machine.
2012 Suzuki GSX1250FA ST/SEA Touring - Canadian Specifications/Technical Details
US MSRP Price: $11,699 USD
Canada MSRP Price: $12,899 USD
Chassis
Color Black, Blue
Brakes Front Disc brake, twin
Brakes Rear Disc brake
Curb Weight 254 kg (560 lbs)
Final Drive RK GB50GSVZ3, 118 links
Fuel Tank Capacity
Ground Clearance 135 mm ( 5.3 in)
Overall Length 2130 mm (83.9in)
Overall Width
Seat Height 785/805 mm (30.9/31.7 in) - Low/High
Suspension Front Telescopic, coil spring, oil damped
Suspension Rear Link type, coil spring, oil damped
Tires Front 120/70ZR17M/C (58W), tubeless
Tires Rear 180/55ZR17M/C (73W), tubeless
Transmission 6-speed constant mesh
Wheelbase 1485 mm (58.5 in)
Engine
Engine 1255 cc (76.6 cu. in), 4-stroke, liquid-cooled, DOHC
Bore Stroke 79.0 mm (3.110 in) x 64.0 mm (2.520 in)
Compression Ratio 10.5 : 1
Fuel System Fuel injection
Ignition Electronic ignition (Transistorized)
Lubrication Wet sump
Starter Electric
Warranty
Warranty 12 Month Limited Warranty
Re: This Week - 2012 Suzuki GSX1250FA Touring: Vote & Discus
#2 Unread post by Wrider »
Looks like I found the next bike I'll be buying! Exactly what I'm looking for!
Well except for the full fairing. 1/2 fairing and it's perfect!
madjak30
Years Riding: 13
#3 Unread post by madjak30 »
The Bandit 1250S was the bike I wanted when I bought my MT-01...but I couldn't find one for a low enough price and now I'm kinda glad...I think this is a much nicer looking bike, and it has a much more modern gauge package with a gear indicator. To me, this is the ultimate in 'bang for your buck' sport touring...and with the new bags that more closely suite the style of the bike (old ones were basically the same Suzuki bags that are on the Vstrom...bleh), I like it a lot!!
Voted: AWESOME!
Later.
Grey Thumper
Real Name: Dino
madjak30 wrote:To me, this is the ultimate in 'bang for your buck' sport touring.
Indeed. The sport tourer for the rest of us. Awesome.
jstark47
#5 Unread post by jstark47 »
Agreed. A sport tourer that doesn't weigh 700 lbs and cost almost $20K. Awesome!
HYPERR
#6 Unread post by HYPERR »
Meh...not feeling it... :?
#7 Unread post by Wrider »
HYPERR wrote:Meh...not feeling it... :?
You ride a Hypermotard, your opinion on looks don't count! :laughing:
#8 Unread post by High_Side »
I ride a Superduke so mine likely don't count either but I agree with HYPERR :mrgreen: . Taking the retro semi-cool Bandit, shrink wrapping it in plastic and changing the name does not make a cool bike. It's likely a very functional bike, and it doesn't look bad but that on it's own does not make it cool.
On another note Mrs. High_Side sat on one as a potential touring bike to compliment her Monster. Although the seat height worked this bike is really top heavy compared to the competition (CBF1000). Perhaps a result of the retro design, but still a weak point.
So it's functional and is a decent bike but the name of the forum is cool wall - so therefore: uncool.
I think the line "Best bang for your buck" really applies highly to the 2012 Suzuki GSX1250FA Touring, as it did it's previous incarnation, the Bandit 1250S and 1250 as well as the 1200 and GSX1100E all the way back to the GS1000E it came from back in (1978-79?). I would easily debate this is the biggest cc (and best) motorcycle you can get for such little money. For that, you get a legendary engine known for it's torque and reliablility (the GS series of engines since 1976 have proven themselves time and time again in racing, street and modding), and a chassis that's decent, and handling that's good. But this is a bike that's all about it's engine (IMO) at an amazing value.
I've ridden the Bandit 1250S for a couple of weeks (Thanks Mashby) and it's a very linear powerband, there is little need to down shift at all and is eagar to go faster than the speed limits... the engine doesn't have a lot of "character" to it, it's just power.
In the end, I can't think of a better bike for the money (in it's cc size) with such a reliable and torquey engine and that alone gives it an: AWESOME vote from me.
:revv:
JackoftheGreen
Real Name: Eric
#10 Unread post by JackoftheGreen »
I don't know enough about the ST class to pass out Awesomes or Fails when one comes up. So working within my two choices, here's what I see...
This thing weighs about what my Vulcan weighs, and for an ST with a liter+ motor and full fairing that's pretty impressive. The price also makes an impression, enough so that if I ever thought to venture into the ST experience this bike may be the one I'd do it on depending on it's carrying capacity and tank size.
Not a fan of the panniers though. Why is it all the side cases on these ST bikes look like the case my miter saw is in? I know they're going for 'rugged', but everything comes across looking 'cheap'. Like maybe you could just buy the most recent rollback tool box at WalMart, drill a couple holes in the back and mount it to your bike (at a fraction of the cost of hard bags!) Top case still looks like the fat kid on a diving board, there's no way to make those look cool anyway.
So, what I don't like about this bike could unbolt in a few minutes, but in doing so you wouldn't have much T left in your ST.
I'll still throw this a Cool. For the price, it looks like exceptional value.
