More photos and information: http://www.totalmotorcycle.com/motorcyc ... ladius.htm
2012 Suzuki SFV650 Gladius
The Suzuki SFV 650 provides a new definition of aggressive sport bike styling. With a trellis frame openly highlighting its chassis design, stylish five-spoke cast aluminum-alloy wheels and a bold, upswept exhaust system, the Gladius promises exciting performance. The proven 650 V-twin engine provides the power you crave.
Fashion Meets Technology
Introducing a unique work of motorcycle art, a masterpiece of fresh styling.
Powered by a sporty 645cc V-Twin engine featuring the best of modern technology, delivering broad power.
A motorcycle that blends traditional displacement with an elegant new look, smooth handling and a friendly, comfortable ride.
Think of it as a combination of style and technology, efficiency and fashion, an unmatched value on two wheels, with an extra dose of daily fun included.
It is called the Suzuki SFV650 (GLADIUS).
Unveiled in Paris, Suzuki's all-new Gladius 650 was a complete surprise to the press. A new naked middleweight model featuring Suzuki's legendary 650cc V-Twin engine, the Gladius boasts unique styling in a user-friendly package.
With a fuel injected, twin plug head engine delivering enhanced performance, combined with great style and neutral lightweight handling, the Gladius is perfect for first time or experienced riders alike.
2012 Suzuki SFV650 Gladius Key Features
39mm throttle bodies
645cm3 fuel-injected DOHC 90-degree V-Twin engine based on the SV650 power plant with proven long-term reliability, broad power and quiet rumble.
Twin Iridium spark plugs for each cylinder improve combustion. Use of Iridium alloy allows the electrode to be finer to produce a stronger spark.
Race-proven Suzuki Composite Electrochemical Materials (SCEM) cylinder reduces friction and improves heat transfer, durability and ring seal.
Suzuki Dual Throttle Valve (SDTV) downdraft digital fuel injection enhances throttle response and acceleration and helps reduce emissions.
10-hole, extra-fine-atomization fuel injectors improve combustion efficiency.
Automatic Idle Speed Control (ISC) system integrated into each throttle body improves cold starting and reduce emissions
Elegant styling with a richly curved bodywork highlighted by edgy frame covers, seat rail/engine cover detailing and buffed stainless steel muffler cover.
Steel-tubing compact trellis frame.
Color combinations and contrasts of front fender, radiator covers, fuel tank covers, side covers, steel fuel tank and frame in each color scheme attractively characterize fresh and stylish appearance of the GLADIUS.
Two-tone seat, with a relatively low 785mm (30.9-inch) height, ample padding and bolstered rear edges to well-support the rider's hips.
Comfortable riding position composed with tubular handlebar shape, footpeg and seat positioning, and the slim fuel tank/seat meeting section.
41mm-stanchion-tube front forks and progressive-link rear suspension are both spring-preload adjustable.
5-spoke 17-inch cast aluminum-alloy wheels, shod with Dunlop Qualifier sport radial tires.
Front brakes with floating 290mm discs and dual-piston calipers; rear brake with 240mm disc and a single-piston caliper.
Carefully shaped multi-reflector headlight incorporates high and low beams as well as a position light, and is flanked by clear-lens turn indicators.
Instrumentation includes an analog tachometer and LCD speedometer, digital dual trip meters, odometer, LCD digital clock and gear-position indicator.
Indicator lights include a two-way remaining fuel warning lamp backed up by an LCD reserve trip meter.
2012 Suzuki SFV650 Gladius - Canadian Specifications/Technical Details
Canada MSRP Price: $8,299 CDN
UK RRP Price: £5,465 GBP
USA MSRP Price: NA
Chassis
Brakes Front 2-piston calipers, 290 mm disc, twin
Brakes Rear 1-piston caliper, 240mm disc
Color Pearl Mirage White/Glass Sparkle Black and Glass Sparkle Black
Curb Weight 202kg (446lbs)
Final Drive Chain
Fuel Tank Capacity 14.5 L (3.19 Imp gal)
Ground Clearance 140mm (5.5 in.)
Overall Length 2130 mm (83.9 in.)
Overall Width 760 mm (29.9 in.)
Seat Height 785 mm (30.9 in.)
Suspension Front Telescopic, coil spring, oil damped
Suspension Rear Lynk type, coil spring, oil damped, spring preload 7-step adjustable
Tires Front 120/70ZR17M/C (58W), tubeless
Tires Rear 160/60ZR17M/C (69W), tubeless
Transmission 6-speed, constant mesh
Wheelbase 1445mm (56.9 in.)
Engine
Bore Stroke 81.0 mm x 62.6 mm
Compression Ratio 11.5 : 1
Engine 645 cc, 4-stroke, 2-cylinder, liquid-cooled, DOHC, 90-degree V-Twin
Fuel System Fuel Injection
Ignition Electronic ignition (Transistorized)
Lubrication Wet sump
Starter Electric
Warranty
