More photos and information: http://www.totalmotorcycle.com/motorcyc ... 7Stone.htm
2013 Moto Guzzi V7 Stone
NEW FOR 2013
An Evolution That Represents Tradition
This represents the entry level model to the range, more for the versatility of its style than for essentiality in its equipment. Thanks to the new lightweight, minimalist alloy wheels, the new V7 Stone attracts a more varied audience than the other two versions, clearly inspired, even in the chromium plating choices, by the legendary Moto Guzzi bikes of the past.
Celebrating 91 Years of Style
Elegant and Italian, the all new 2013 Moto Guzzi V7 family assures unmistakable presence derived from the original V7's of old whilst still offering the very best in technical specification and performance available on motorcycles of today.
The Bike
The design of the new V7 tells of the historic lineage of the model through a mix of forms and volumes which cite the famous ancestors, from the V7 750 Special remembered in the accents and the side panels, to the V7 Sport, which influenced the tank, the main new feature introduced in the new V7.
A change in look, now more imposing in form and capacity, the new tank brings with it a superior material perception of metal with respect to polyethylene, the material which was used to make the previous unit. This is thanks to the most advanced moulding technologies which allow construction of a metallic tank which is the same size, but lighter and with greater capacity compared to the previous polyethylene unit, reaching a record value of 22 litres which, together with the reduced consumption, ensures a range of up to 500 km. This is further proof of the design philosophy that guided the entire V7 project where innovation of the processes restored the pleasure to the rider of gripping a real, resounding metal tank in true Moto Guzzi tradition.
The rest of the new V7 design confirms that alchemy of tradition and modernism introduced in 2008 with the first V7 Classic, where, through the generous chrome trim, enthusiasts will be able to appreciate the cigar shape of the silencers, the dials on the instrument panel, clearly inspired by the Veglia-Borletti from the 1970s, the flat and long saddle, with the proud "Moto Guzzi" inscription emblazoned on the rear part as well as the new valves covers.
The Moto Guzzi V7, iconic and prestigiously manufactured, is now available in three versions, two touring and one sport, respectively the V7 Stone, V7 Special and the V7 Racer. Just like in 1971 when the sport version completed a range made up of the dominating V7 and V7 Special.
2013 Moto Guzzi V7 Stone - Specifications/Technical Details
US / CAN MSRP Price: Stone: PRICE: $8,390.00; V7 Classic: PRICE: $8,990.00; V7 Special: PRICE: $8,990.00; V7 Racer: PRICE: $9,990.00
UK/European MSRP Price: £6,499
Italian MSRP Price: €7,990 EUR
ENGINE 90° V-twin with 2 valves per cylinder
DISPLACEMENT 744cc
MAXIMUM POWER 37Kw (50 HP) at 6,200 rpm
MAXIMUM TORQUE 60 Nm at 2,800 rpm
EXHAUST SYSTEM 3 ways catalyzed with sonda lambda
GEARBOX 5 speed
SECOND DRIVE Shaft drive
FRONT SUSPENSION 40mm Marzocchi hydraulic telescopic fork
REAR SUSPENSION Light weight alloy swing arm with 2 adjustable spring preload shock absorbers
FRONT BRAKE Single stainless steel floating disc, 320mm, with 4 piston caliper
REAR BRAKE Single steel disc, 260mm, with 2 opposed piston caliper
WHEELS Polished alloy, spoked [6 spoke alloy V7 Stone]
TYRES 100/90 18 (front) – 130/80 17 (rear)
LENGTH 2,185mm
WIDTH 800mm
HEIGHT 1,115mm
SEAT HEIGHT 805mm
DRY WEIGHT 179kg
FUEL TANK CAPACITY 22 litres (reserve 4 litres)
