More photos and information: http://www.totalmotorcycle.com/photos/2 ... andard.htm
2009 Ridley Auto-Glide Standard
The 2009 Auto-Glide Standard is everything you want in a Ridley; fit and function at a great price. As Ridley's entry level Auto-Glide model, the Standard offers the low 24.5" seat height, light 460 pound weight, and fully automatic transmission for less then $14,000! If you're in the market for a quality made affordable automatic motorcycle this is the Ridley model for you!
Features & Benefits
FEATURES
- Ridley 750 V-Twin - Type I Automatic Transmission
- 5 Gallon Fuel Tank - Slim Rubber Hand Grips
- Right Side Final Drive - Front & Rear Turn Signals
- Cruiser Handlebars - Tombstone Taillight
- Chrome Headlight - Mechanical Type Speedometer
BENEFITS
- Twist & Go Centrifugal Clutch - Low Center of Gravity
- Low 24.5" Seat Height - Incredible Attention to Detail
MODEL PRICING
Base Model MSRP : $13,900
Delivery : $650
MSRP : $14,550
OPTIONS
Drive : Belt Final Drive +$500
Drive : Type II CVT Upgrade +$675
Ergo : Pullback Handlebars +$100
Ergo : Ape Hanger Handlebars +$80
Ergo : Beach Bar Handlebars +$20
Seat : Touring (Black or Gray) +$140
Seat : Studded Touring (Black) +$180
Seat : Two Up (Black or Gray) +$75
Seat : Passenger Pinion (Black) +$161
2009 Ridley Auto-Glide Standard - USA Specifications
Base Model MSRP : $13,900 + Delivery : $650 = MSRP : $14,550
ENGINE
Manufacturer : Ridley®
Configuration : 90° V-Twin
Displacement : 750
Cooling System : Air
Compression Ratio : 8.5 : 1
DRIVE SYSTEM
Transmission Type : Automatic CVT
Clutch Type : Centrifugal
Engagement RPM : 1100 RPM
RPM @ 85 MPH : 3600 RPM
Primary Drive : Belt
Final Drive : Belt
SIZES & WEIGHT
Dry Weight : 460 lbs. / 209 kg
Wheelbase : 66" / 167.6 cm
Overall Length : 97" / 246.4 cm
Seat Height : 24.5" / 62.2 cm
BRAKES
Brake Type : Hydraulic (DOT 5)
Front Brake : Four Piston
Rear Brake : Four Piston
Remember that you can suggest a model to appear on the Cool Wall each week right here: viewtopic.php?f=61&t=40774
