More photos and information: http://www.totalmotorcycle.com/motorcyc ... ambler.htm
2012 Triumph Scrambler
Classic Triumph motorcycles. The way bikes should look, run and sound.
A modern interpretation of a timeless classic, the Scrambler demands attention wherever it goes.
2012 Scrambler - The stuff of Hollywood legends. No-nonsense 60s attitude. Ready for action.
Scrambler. Stripped down. Purposeful. Head turning. The stuff of Hollywood legends. With the latest twist. Our latest fuel injected, air-cooled 865cc parallel-twin, reworked with different timings for that distinctive exhaust note from those classy high swept chrome pipes. Fork gaiters. Pulling strongly from low down. An accessible ride that's easy and relaxed. What it's always been. Only better. Scrambler.
2012 Triumph Scrambler Features and Benefits
Fuel Efficiency:
46 MPG City / 60 MPG Highway
Exhaust System:
High level stainless steel headers with twin chromed silencers
Front Wheels:
36-spoke 19 x 2.5in
Engine:
Air-cooled, DOHC, parallel-twin, 270º firing interval
A sense of adventure from back in the day. A modern interpretation of a timeless classic, the Scrambler demands attention wherever it goes. Triumph's legendary 865cc air-cooled parallel-twin engine with modern fuel injection and plenty of torque. The distinctive sound from the 270 degree firing order and the twin stainless steel upswept pipes. Add classic styling details and it's easy to understand why the Scramblers of the past were the stuff of Hollywood legends.
2012 Triumph Scrambler - Specifications/Technical Details
USA MSRP Price: $8,799 USD
Canada MSRP Price: $8,799 CDN
Engine and Transmission
Type Air-cooled, DOHC, parallel-twin, 270º firing interval
Capacity 865cc
Bore/Stroke 90 x 68mm
Fuel System Multipoint sequential electronic fuel injection with SAI
Exhaust High level stainless steel headers with twin chromed silencers
Final Drive X ring chain
Clutch Wet, multi-plate
Gearbox 5-speed
Oil Capacity 4.5 litres (1.2 US gals)
Chassis, Running Gear and Displays
Frame Tubular steel cradle
Swingarm Twin-sided, tubular steel
Wheel Front 36-spoke 19 x 2.5in
Rear 40-spoke 17 x 3.5in
Tire Front 100/90 19
Rear 130/80 17
Suspension Front Kayaba 41mm forks, 120mm travel
Rear Kayaba chromed spring twin shocks with adjustable preload, 106mm rear wheel travel
Brakes Front Single 310mm disc, Nissin 2-piston floating caliper
Rear Single 255mm disc, Nissin 2-piston floating caliper
Instrument Display/Functions Analogue speedometer with odometer and trip information
Dimensions and Capacities
Length 2213mm (87.1in)
Width (handlebars) 860mm (33.8in)
Height without mirrors 1202mm (47.3in)
Seat Height 825mm (32.5in)
Wheelbase 1500mm (59.0in)
Rake/Trail 27.8º/105mm
Fuel Tank Capacity / Efficiency 16 litres (4.2 US gals)
Wet Weight (ready to ride) 230 kg (506 lbs)
Performance (measured at crankshaft to 95/1/EC)
Maximum Power 59PS / 58bhp / 43 kW @ 6800rpm
Maximum Torque 68Nm / 50 ft.lbs @ 4750rpm
Fuel Efficiency 46 MPG City / 60 MPG Highway *Estimated from fuel economy tests on a sample motorcycle conducted under ideal laboratory conditions. Actual mileage may vary based upon personal riding habits, weather, vehicle condition, and other factors.
