2013 Moto Guzzi Griso 1200 8V SE - Voted: 83.3%
Your Coolness Factor of the 2013 Moto Guzzi Griso 1200 8V SE is..
View results
2013 Moto Guzzi Griso 1200 8V SE on the Total Motorcycle Cool Wall
More photos and information: http://www.totalmotorcycle.com/motorcyc ... 008VSE.htm
The 2013 Moto Guzzi Griso 8V SE might well be one of the most unique and captivating motorcycles to come out of the Mandello Del Lario factory. The bold character expressed in the nonconformist styling of the Griso is given further emphasis by the aggressive new black/silver color concept in a matte tone that flows elegantly with the numerous black painted metal elements such as the frame, wheels, steering plates, handlebar and instrument panel covers.
Griso 8V SE has impeccable style; this machine is an instinctive creation, pure, solid and distinctive and in many ways a work of art.
The design details are discreet but elegant and pure quality; the lines blend together and are accentuated by the chrome finishing and satin metal form. The fuel tank lends itself superbly to the strong frame creating an aerodynamic teardrop body which is continued through to the tail which houses three high intensity LED light units.
The Griso is decidedly masculine and powerful yet the “Quattrovalvole” engine seems to be set like a jewel in a frame that shows off its revolutionary design to the utmost effect. Returning to the performance, it becomes obvious that the sophisticated components are not mere technical details included for the sake of style but enhances performance and provides guaranteed reactivity.
The Moto Guzzi Griso SE features the latest transverse 90° V-twin from the “Quattrovalvole” series and produces a peak power of 110 hp at just 7500 rpm with a whopping 108Nm of torque at 6400 rpm allowing the Griso SE to dominate the road with a smooth power delivery whilst the outstanding chassis keeps all those horses in check. The chassis is comprised of a twin overhead tubular element made from high tensile steel and generously sized lateral reinforcement of the lower cradle with ribbing that has been added not only for aesthetic purposes but also for increased rigidity.
The stylish black and silver livery contrasts elegantly with the black metal of the frame which also ties in the black rims, steering plates and handlebars. It also boasts chrome spoke wheels and colour coordinated badges. The incredible two-into-one exhaust system highlights the Griso SE’s boldness and further ads to the character of this unique motorcycle. Its details like this that leave an impression before you even ride the Moto Guzzi Griso 8V SE.
2013 Moto Guzzi Griso 1200 8V SE - Specifications/Technical Details
US MSRP Price: $12,690 USA
Canada MSRP Price: $13,590 CDN
ENGINE
Type Four-stroke V 90 twin
Cooling Air and oil cooled with independent cooling pump
Capacity 1,151cc
Bore and stroke 95 x 81.2 mm
Compression ratio 11:01
Maximum power output Over 110 hp at 7,500 rpm
Max Torque 80 foot pounds at 6,400 rpm
Fuel supply/ignition Multipoint sequential electronic injection, Magneti Marelli IAW 5A phased, alfa-n system; 2 x Ø50 mm throttle bodies with Weber IWP 189 injectors, Lambda probe.
Exhaust system Stainless steel two-into-one 3-way catalysed with Lambda probe.
TRANSMISSION
Gearbox 6 speed
Lubrication Oil bath
Final drive CA.R.C reactive drive; double universal joint with floating bevel gear, ratio 12/44 = 1 : 3,666
Clutch Single plate with integrated flexible couplings
CHASSIS / SUSPENSION / BRAKES
Frame High tensile steel tubular twin cradle
Wheelbase 61 inches (1,554 mm)
Trail 4.25 inches (108 mm)
Steering rake 26.30°
Steering angle. 34°
Front suspension Upside down Ø 43 mm fully adjustable forks (spring preload and hydraulic for rebound and compression) with mounting for radial callipers.
Front wheel travel 120 mm
Rear suspension Progressive single swingarm, fully adjustable monoshock with separate gas reservoir (spring preload and hydraulic for rebound and compression).
Rear wheel travel 110 mm
Front brakes Twin floating 320 mm stainless steel wave discs, Brembo radial callipers with 4 opposed pistons.
Rear brakes Single 282 mm fixed stainless steel disc, floating calliper with 2 parallel pistons.
Wheels Tubeless spoke wheels with aluminium Ber rim and Alpina spokes.
Front wheel 3.50" x 17"
Rear wheel 5.50" x 17"
Front tire 120/70 ZR17"
Rear tire 180/55 ZR17"
DIMENSIONS
Length 89 inches (2,260 mm)
Width 32.6 inches (830 mm)
Height 42.12 inches (1,070 mm)
Saddle height 31.4 inches (800 mm)
Minimum ground clearance 7.28 inches (185 mm)
Dry weight 489 pounds (222 kg)
Fuel tank capacity 4.4 gallons (16.7 litres)
Reserve .5 gallon
Re: This week: 2013 Moto Guzzi Griso 1200 8V SE: Vote Today
This weeks cool wall bike is brought to you by: :star: madjak30 and High_Side :star: who suggested it in our "Suggest the next Cool Wall Bike" thread here: viewtopic.php?f=61&t=40774&start=230
Thanks for the great suggestion!
montanalifter
Real Name: Bill
#3 Unread post by montanalifter »
I like it a lot. Unique is written all over this bike.
BRUMBEAR
Real Name: Dave
Years Riding: 40
#4 Unread post by BRUMBEAR »
I really like it I wouldn't buy one cause I already got a v-50 :D but I wouldn't kick it outa bed for eating Ritz crackers if ya folla me
there aint nothin like it
HYPERR
#5 Unread post by HYPERR »
Awesome! I want one! :D
madjak30
Years Riding: 13
#6 Unread post by madjak30 »
I voted: AWESOME
It's a really nice looking bike, but I still like mine better...but if you're in the States and can't get the MT-01, this is a nice alternative. ;-)
#7 Unread post by High_Side »
Awesome - always loved this bike, but prefer the older green bike / brown seat version if I had the choice. When you look around there really isn't another bike like it out there.
jstark47
#8 Unread post by jstark47 »
Not my favorite color scheme for this bike - I liked the ones that were the muted green color with the medium-brown leather seat.
Nonetheless....... it's a Griso 8v. One of my all-time motorcycle lust objects. Automatic AWESOME!! If Piaggio would get serious about their ridiculously sparse dealer network, I woudl SO own one of these.
BobK
Years Riding: 43
#9 Unread post by BobK »
I had a ride on one and it truly is awesome. I would have bought one if I hadn't had a bad experience with the local dealer.
HYPERR
#10 Unread post by HYPERR »
High_Side wrote:Awesome - always loved this bike, but prefer the older green bike / brown seat version if I had the choice.
jstark47 wrote:Not my favorite color scheme for this bike - I liked the ones that were the muted green color with the medium-brown leather seat.
That was the Special Edition Tenni that came out in 2009 and is my fave Griso as well. :kicking:
