1988 yamaha radian back brake
Re: 1988 yamaha radian back brake
#11 Unread post by Wrider »
There's supposed to be a nut on the screw. The nut should be up against the piece the screw is in, keeping the screw in place.
kflint79
Real Name: Keith
My Motorcycle: 1988 yamaha Radian
#12 Unread post by kflint79 »
does the screw act as the stop and if so does it go agianst the pedal or next to it?
kflint79
Real Name: Keith
#13 Unread post by kflint79 »
#14 Unread post by Wrider »
The screw head acts as the stop. The nut keeps the screw from moving in and out.
kflint79
Real Name: Keith
#15 Unread post by kflint79 »
thanks have heard of the engine leaking? what can I check it leaks oil there is usually a nice little puddle when it sits took the engine out it looks like the oil pan. I bought it used have no idea of maintenance record. The person I bought it from thought it was the crankcase seal.
#16 Unread post by Wrider »
You'll just have to trace the oil drop to find out where it's coming from.
Easiest way: Take it for a ride. When you get home, use foot powder/baking soda/flour/some sort of white powder and cover the area you suspect of leaking. Let it sit and you'll find it via the trails.
