For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... 0-BOSS.htm
2014 Suzuki Boulevard C50 BOSS
Go ahead, what are you waiting for?
One word comes to mind to describe the Suzuki Boulevard C50 B.O.S.S. - classic, a classic that just got better! The C50 B.O.S.S. is a cruiser that offers blacked out classic styling, unmatched comfort, and thrilling performance. With kicked out front ends, wide handlebars, smooth suspension, and well-cushioned seating; Suzuki's design team has the rider's comfort in mind. The C50 B.O.S.S. boasts a fuel-injected, 45-degree, V-twin engine that cranks out 805cc that generates abundant torque down low and matched by exciting top-end performance.
Cruise down the boulevard and own the night with a Suzuki B.O.S.S..
Climb aboard a true classic. Kick back and enjoy the timeless style that made riding synonymous with freedom. It’s all about the laid-back stance, broad saddle, and that irresistible rumble that only a cruiser can provide.
2014 Suzuki Boulevard C50 BOSS Total Motorcycle Key Features
The C50 B.O.S.S. has the following features blacked out: Head lamp housing, Rearview mirrors, Handlebars, Clutch lever, Brake lever, Handle switches, Front fork outer tubes, Steering stem head, Tank cover, Air cleaner cap, Clutch cover, Side covers, Second air valve cover, Generator cover, Final gear case, Taillight cover, Front brake caliper, Front and rear wheels, Mufflers, Prop stand
2014 Suzuki Boulevard C50 BOSS - Total Motorcycle USA Specifications/Technical Details
US MSRP Price: TBA USD
Engine
Engine 805cc, 4-stroke, 2-cylinder, liquid-cooled, SOHC, 45 degree V-Twin TMW
Bore x Stroke 83.0 mm x 74.4 mm (3.268 in x 2.929 in)
Compression Ratio 9.4 : 1
Fuel System Suzuki Fuel Injection
Starter Electric
Lubrication Wet sump
DriveTrain
Transmission 5-speed constant mesh
Final Drive Shaft Drive
Chassis
Suspension Front Telescopic, coil spring, oil damped
Suspension Rear Link type, coil spring, oil damped
Brakes Front Disc brake
Brakes Rear Drum brake
Tires Front 130/90-16M/C 67H, tube type
Tires Rear 170/80-15M/C 77H, tube type
Fuel Tank Capacity 4.1 US - Including Reserve
Color Glass Sparkle Black
Electrical
Ignition Electronic ignition (Transistorized)
Spark Plug NGK DR8EA or DENSO X24ESR-U
Headlight 12V 60/55W
Tail Light 12V 21/5W
Dimensions and Curb Weight TMW
Overall Length 2500 mm (98.4 in)
Overall Width 955 mm (37.6 in)
Wheelbase 1655 mm (65.2 in)
Ground Clearance 140 mm (5.5 in)
Seat Height 700 mm (27.6 in)
Curb Weight 611 lbs
Warranty
12 month unlimited mileage limited warranty.
