spuddering and popping
jakee1
Real Name: jake
Years Riding: 3
My Motorcycle: 1988 honda shadow 1100
#1 Unread post by jakee1 »
:? spuddering and popping when giving throttle, have already cleaned carbs and checked boots can anyone give me some advice on what to check next. :frusty:
Re: spuddering and popping
#2 Unread post by Johnj »
Well I guess you could check your coils, plug wires,and plugs. Have you done anything like cut down the baffles to it?
BRUMBEAR
Real Name: Dave
Years Riding: 40
#3 Unread post by BRUMBEAR »
Stock exhaust? If you changed exhaust did you jet the carbs? Ground issue? Voltage issue?
there aint nothin like it
jakee1
Real Name: jake
Years Riding: 3
#4 Unread post by jakee1 »
havent done anything different it was running fine then all of a sudden it just started running like crap, so i cleaned the carbs bc it had some trash in the tank, didnt make any difference. i also installed a in line filter, after it still didnt help i uninstalled the filter, still no difference.
jakee1
Real Name: jake
Years Riding: 3
#5 Unread post by jakee1 »
i will check for ground issues, and last year i put new coils and the pickup on the crankshaft. also it reved fine a couple of times yesterday then back to the same crud.
#6 Unread post by Johnj »
Sounds to me that the carbs are not clean. I know you cleaned them, but did you clean out all the jets and passageway. That happens when there's trash in the tank.
jakee1
Real Name: jake
Years Riding: 3
#7 Unread post by jakee1 »
well i cleaned the carbs again this time really took my time and made sure it was clean and still no change, could a loose timing chain be the problem.
#8 Unread post by Johnj »
Have you got a manual? What does it (the service manual) say to check?
BRUMBEAR
Real Name: Dave
Years Riding: 40
#9 Unread post by BRUMBEAR »
check your plug wires
jakee1
Real Name: jake
Years Riding: 3
#10 Unread post by jakee1 »
i noticed some backfiring back through one carb when trying to rev yesterday. the manual says to check ignition timing, plugs and wires. im thinking i may have a valve sticking, could this be the problem?
