For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... R-APRC.htm
2013 Aprilia RSV4 R APRC
FROM APRILIA'S DOMINATION IN THE WORLD SUPERBIKE CHAMPIONSHIP, THE MOTORCYCLE THAT ALREADY SET NEW STANDARDS FOR THE SUPERSPORTS STREET BIKE GENRE: APRILIA RSV4 R APRC.
A SYMBOL OF THE “RACE READY” BIKE, RSV4 R APRC IS EVEN FASTER AND SAFER ON THE TRACK TODAY THANKS TO THE APRC DYNAMIC CONTROLS PACKAGE.
THREE INNOVATIVE SYSTEMS PATENTED BY APRILIA WHICH CONSTANTLY MONITOR THE DYNAMIC CONDITIONS OF THE BIKE AND OPERATE ON THE ENGINE CONTROL TO SUPPORT THE RIDER IN REACHING MAXIMUM RACING SPEED.
Racing heritage
Created with the single-minded goal of being simply the best on the track and on the road, since its inception the Aprilia RSV4 has astonished the world with its looks, technology and performance. The first 65° V-4 engine ever in a sports production bike, a chassis worthy of a 250 GP, Ride By Wire, multimap engine management: all these are accomplished achievements for the Aprilia RSV4, that tops unique architecture and specs with Aprilia's signature excellent rideability brought to the next level.
2013 Aprilia RSV4 R APRC - Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $18,999 USD
Canada MSRP Price: $19,599 CDN
Engine: Aprilia longitudinal 65° V-4 cylinder, 4-stroke, liquid cooling system, double overhead camshafts (DOHC), four valves per cylinder.
Bore x Stroke: 78 x 52.3 mm
Total displacement: 999.6 cc
Compression ratio: 13:1
Maximum power at the crank: 180 HP (132.4 kW) at 12,250 rpm
Maximum torque at the crank: 115 Nm at 10,000 rpm
Fuel system: Airbox with front dynamic air intakes. Variable length intake ducts controlled via ECU. 4 Weber-Marelli 48-mm throttle bodies with 8 injectors and latest generation Ride-by-Wire engine management. Choice of three different engine maps selectable by the rider with bike in motion: T (Track), S (Sport), R (Road) Totalmotorcycle.com
Ignition: Magneti Marelli digital electronic ignition system integrated in engine control system, with one spark plug per cylinder and “stick-coil”-type coils.
Starting: Electric
Exhaust: 4 into 2 into 1 layout, single oxygen sensor, lateral single silencer with engine control unit-controlled butterfly valve and integrated trivalent catalytic converter (Euro 3).
Generator: Flywheel mounted 420W alternator with rare earth magnets.
Lubrification: Wet sump lubrication system with oil radiator and two oil pumps (lubrication and cooling).
Gear box: 6-speed cassette type gearbox 1st: 38/16 (2.375) 2nd: 35/18 (1.944) 3rd: 28/17 (1.647) 4th: 32/22 (1,455) 5th: 34/26 (1,308) 6th: 33/27 (1,222) Gear lever with Aprilia Quick Shift electronic system (AQS)
Clutch: Multiplate wet clutch with mechanical slipper system.
Primary drive: Straight cut gears and integrated flexible coupling, drive ratio: 73/44 (1,659).
Final drive: Chain: Drive ratio: 42/16 (2.625).
Frame: Twin-spar adjustable aluminium frame, with castings and pressings. Envisaged adjustments: • headstock position and rake • engine height • swingarm pin height Öhlins adjustable steering damper
Front suspension: Öhlins Racing upside-down fork, Æ 43-mm stanchions (with Tin surface treatment). Low profile forged aluminium radial caliper mountings. Completely adjustable spring preload and hydraulic compression and rebound damping. Wheel travel: 120 mm. Totalmotorcycle.com
Rear suspension: Double braced aluminium swingarm; mixed low thickness and sheet casting technology. Öhlins Racing mono-shock absorber with completely adjustable piggy-back in: spring preload, wheelbase, hydraulic compression and rebound damping. APS progressive linkage. Wheel travel 130mm.
Brakes: Front: Dual 320-mm diameter floating stainless steel disc with lightweight stainless steel rotor and aluminium flange with 6 pins. Brembo monobloc radial callipers with 4 Æ34-mm opposite. Sintered pads. Totalmotorcycle.com . Radial pump and metal braided brake hose. Rear: 220-mm diameter disc; Brembo floating calliper with two Æ32mm isolated pistons. Pump with integrated tank and metal braided hose .
Wheels: Aprilia forged aluminium alloy rims, completely machined, 5 split spokes. Front:3.5”X17” Rear: 6”X17”
Tires: Radial tubeless. Front: 120/70 ZR 17 Rear: 200/55 ZR 17 (alternative: 190/50 ZR 17; 190/55 ZR 17)
Dimensions: Max. length: 2040 mm Max. width: 735 mm (at the handlebar) Max. height: 1120 mm Min. height from the ground: 130 mm Saddle height: 845 mm Centre to centre distance: 1420 mm Trail: 105 mm Steering angle:24.5°
Dry weight: 179 kg *
Fuel tank capacity: 17 litres (4-litre reserve included).
