For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... CA-ABS.htm
2014 Honda Valkyrie GL1800CA ABS
The Gold Wing 1800 stripped down to its hot rod heart. Bigger, badder and better than ever, the Valkyrie is back...
The Valkyrie® name is legendary, and the machine first introduced in 1996 has a hard-core following to this day. Now for 2014, the Valkyrie takes that unmistakable swagger to a whole new level. It's a winning formula: Take a legendary machine, strip it down to the essentials to shed pounds, wrap it in minimalist bodywork and power it with an engine that produces ground-shaking torque and an unmistakable six-cylinder howl. The core of this remarkable custom is Honda's unique 1832cc liquid-cooled horizontally opposed six-cylinder engine that also powers the Gold Wing® and Gold Wing F6B. With an awe-inspiring power-to-weight ratio, aluminum twin-spar frame and suspension system tuned for serious riders, the Valkyrie is all about unparalleled performance and style. With a curb weight of 750 pounds, the Valkyrie is a welterweight with a heavyweight punch, that also includes modern touches; LED headlight, taillight and turn signals, multi-function digital LCD instrumentation and available Anti-Lock Braking System. The Valkyrie is one totally cool ride that's set so far apart from anything else on the market it has to be experienced to be believed.
GL1800C - hot rod heart
2014 Honda Valkyrie GL1800CA ABS - http://www.Totalmotorcycle.com Specifications/Technical Details
US MSRP Price: $ See Dealer for Pricing in USD
Canadian MSRP Price: $19,999 CDN
ENGINE
Engine Type 1832cc liquid-cooled horizontally opposed six-cylinder
Bore and Stroke 74mm x 71mm
Compression Ratio 9.8:1
Valve Train SOHC; two valves per cylinder
Induction PGM-FI, Programmed Fuel Injection
Ignition Computer-controlled digital with 3-D mapping
DRIVE TRAIN
Transmission Five-speed
Final Drive Shaft
CHASSIS / SUSPENSION / BRAKES
Front Suspension 45mm cartridge fork with anti-dive system, TBD inches travel
Rear Suspension Pro Arm® single-side swingarm with Pro-Link® (http://www.Totalmotorcycle.com) single shock with hydraulic spring-
preload; TBD inches travel
Front Brake Dual 310mm front discs; optional ABS
Rear Brake 316mm rear disc; optional ABS
Front Tire 130/60R-19
Rear Tire 180/55R-17
DIMENSIONS @ http://www.Totalmotorcycle.com
Rake (Caster Angle) 29° 50'
Trail 114mm (4.5 inches)
Wheelbase 67.2 inches
Seat Height 28.8 inches
Curb Weight 754 pounds. Includes all standard equipment, required fluids and a full tank of fuel—ready to ride
Fuel Capacity 6.1 gallons
